Just a few more days...
jlawyer
Just got notice that my '77 EB has been picked up and should be delivered next week.
Unfortunately, in PA, the wheels/tires cannot extend past that body of the vehicle, so I have to get some new shoes when it arrives.
michahoov
Like a kid waiting for Christmas. What part of Pennsylvania are you in?
J
jlawyer
I'm in the Lehigh Valley.
I have a laundry list of things I want to do and the anticipation is leading me to read the posts on this board exhaustively; which isn't helping to make that list any shorter.
Know of any good specialty shops in the area?
michahoov
Don't know anyone out that way. I'm several hours away in central Pa, but I'm sure someone can give you some ideas. Good luck with the Bronco and enjoy. Post some pics when you get it.
J
jlawyer
So it's about time to update this thread...
I was reading another thread and it reminded me that I had started this one...
The shipping company was great; this is the third vehicle I've shipped and Western Auto Transport was by far the nicest. Easy to work with, good communication along the route; their truck was awesome. Wish I had better photos.
0
Got it unloaded and in my driveway... dead battery, had to push. Looks cool though right? I was still pretty stoked.
0
Charged the battery; couldn't get it to stay running.. fired up, ran great, died within about 10 - 20s consistently. After a few days of replacing the battery cables, starter solenoid, checking for fuel, spark, and air I traced it down to an anti-theft feature on the Jacobs electronic ignition system. Scoured the cab, found a switch, and voila.
0
Drove 2 miles, something wasn't right, got it home and parked it.
In the meantime, I needed new wheels and tires to be legal in PA;I decided to go with Black Rock 908B's and 285/70R17's. (Those MT 33x15.5R15's will be for sale in the used section quite soon.)
0
So, put the wheels on start to tune up and this is basically what follows.
  • Removed the hitch, which was incorrectly installed.
  • Replaced the voltage regulator.
  • Replace battery as the other one had dead cells from being deep cycled.
  • Remove the 3.5" body lift and install WH integrated 1" lift.
  • Replaced carb as the old one had melted venturi boosters. Probably from backfiring through the carb.
  • Correct an incorrect shift rod. (Things are starting to come together here.)
  • Master brake cylinder was connected backwards. Fronts to back, backs to front.
  • Install hood and rear hatch gas struts. Gotta do something fun right?
  • Replace lower radiator hose and replace leaking radiator cap.
  • Replaced all lock cylinders.
  • Remove all old wiring and ignition system.
  • Install Pertronix stock look distributor and coil.
  • Replace alternator and power steering belt.
  • Remove A/C belt as idler has a bad bearing.. A/C is the least of my problems at this point.
0
Still runs like crap under load; it's blowing oil out the dip stick and and air is leaking from the valve cover in a let down on cyl. 1. Compression averages to 120lbs....balls.
I really want this up and running before the weather turns, so I started shopping for a 302 roller/short block/long block on craigslist. I found a rebuilt long block for good price and am in the process of swapping that over.
0
The C4 is also out for rebuild as it just drops into third and doesn't even shift manually.
At this point I am pretty annoyed. When I bought it, I mostly focused on rust and general structural integrity; which still seems sound, but I expected more sound mechanicals. My plan was to drive it all summer, then rip it apart over the winter and replace the drivetrain with a coyote or, if Ford pulls through at SEMA, an ecoboost 3.5l. Full frame-off and repaint, blah blah... but I've spent so much time getting it to a point of restoration, I'm just annoyed. Based on the wiring harness, shift rod, and the master brake cylinder, my hypothesis is that whoever the PO was, pulled an EFI engine out and threw in a junk yard 302 and c4. The D20 shifts but I haven't had a chance to test it properly.
okie4570
NW OK
Great looking bronco! Lots of highs and lows in that story.......you've been busy with it that's for sure. Hope you get it all sorted out, that one is too nice to be sitting around under the knife. :)
Mmflpa
Philadelphia, PA
I'm in Philly, and Delconick (aka Northeast Classic Ford Parts) has done all of the work on my Bronco. He's a half hour outside of Philly.
Mountain Ram
Recovering Masshole
Abingdon, VA
Nice looking rig. Buying sight unseen is always worrisome... You just dont know what you are going to get. if the rig is as solid as it looks, the mechanical issues can be sorted out much easier than typical body rot or really bad PO attempts to fix body rot. Most any Bronco you are going to find for a reasonable price will have something to deal with- mechanically, electrically or bodywork.
Enjoy the journey- its a god chance to get to know the rig in and out and truely make it yours. You cant go back and renegotiate the deal and it seems like you know what you are doing. Welcome to the club!!
sprdv1
REBEL
Sweet lookin rig bud. Congrats & best of luck getting the kinks worked out.
just take it one thing at a time :)
Dlish
You that concerned over the tires sticking out past the flairs? Have you been hassled by the PD in your area or just concerned about passing inspection?
Never had an issue around me in PA with that stuff.
mp
Austin, TX
Great job on the mods. Visually looks ten times better than when it rolled off the transport. Upgrades and fixes are a pain, but you will sleep better knowing you made everything right and won't wind up stranded on the side of the road.
J
jlawyer
Thanks, I looked him up. Looks like a great place for parts and information. I've been using Glazier-Nolan Mustang Barn; he's worked on my Mustang before and they've been an awesome help on the Bronco.
0
Yes and no. I've had a hard time passing inspections but I've never been ticketed. I was once pulled over in my tundra and was complimented on the wheels; they stuck out about 2". I used to keep the factory wheels and swap them out for inspections. That was annoying.
No, my main reason is that they just aren't fit for my style of driving and this gets it closer to a LUBR type appearance.
Nice Bronco! You should join MEB. We are planning a wheeling trip next month and a fall cruise. www.earlybroncos.com
Done, I listed you as the sponsor.
J
jlawyer
Two steps forward, three steps back...
  • Pulled the old engine to strip it down and dress the new block.
  • Received the rebuilt C4 back.
  • New block has a Summit cam, http://www.summitracing.com/parts/sum-4400
  • Installed classic Holley carb & manifold.
  • The steering box was damaged beyond repair. Replaced with a Borgeson power steering kit which included Saginaw power steering pump.
  • Kit didn't fit, had to cut, extend, and weld the steering shaft.
  • Degreased and cleaned engine compartment.
  • Bead blasted and painted valve covers and oil pan.
  • Cleaned and painted exhaust manifolds.
  • New brake master cylinder.
  • Reinstalled it all...
  • Replaced turn-signal and horn brushes, installed Nardi steering wheel.
Everything is back in, looks great, engine runs great... except it has a wicked vibration. Vibration feels the worst in park, you can feel it at idle and rises as you increase the throttle. It doesn't feel like it has any real power when you drive, and still vibrates the entire car. Tailgate is loud as hell.
Ordered this bracket..
http://www.wildhorses4x4.com/product/Ford-Small-Block-Test-Bracket
Vibration is definitely in the engine and not the rest of the drivetrain. So now a new flexplate is on the way. Fingers crossed.
Here it is parked this week...
AAByRyF04HxUR7CsrgtgTQTKa
As you can see, I haven't even pulled the temporary plate off yet... maybe some day I'll drive this thing more than a block and it will feel like it actually wants to move.
AABHZsxK3dLuuTk5pCMNREAIa
AAAtzQHjBwpGBi_pfiQ8xIDla
AACpQCVNUCAXRI44Uq3HBuBsa
Oh yeah, the AC's not worth fixing.. Will have to call Vintage Air I guess.
Attac
Your bronco brings back memories for me. My first was a 77 sport with the special decor package. Your work will all be worth it.
My first
AZ73
Looks great! Was wondering about your wheel backspace and if you're running a spacer. And if your tires rubs. Thanks
J
jlawyer
The wheels are 17x8 BlackRock Yuma's... the backspacing is 4.5". No rubbing that I've noticed.
allenfahey
You work fast. It would have taken me a few years to do all that. I'm a slacker.
Once you get it all worked out all your hard work will be worth it. Hopefully you will be able to make it to your first MEB club event on September 19th. INFO
Wonder if that vibration you've got in the engine is a case of mis-matched damper/crankshaft/flexplate gremlins? You're probably familiar with the 28oz vs 50oz imbalance change that Ford made to the 5.0 only. Would definitely make an otherwise smooth engine vibrate like the dickens.
Since that's a roller cam, presumably you've wired the distributor in the HO/351 firing order?
Looking good. Sorry you have not been able to drive it much since getting it. But it'll come. Maybe...%)
Depends on what other "PO mods" you've still yet to find!
