Just flexing
TexasBronco
Waterford, MI
Here is a picture of my bronco doing a little flex in my driveway. I probably could have done a little more but my jack would only go that high. I am running a add-a-leaf (which is actually only about 2") and a 2" block. I plan to go with a more flexible 2 1/2" leaf and the rockers from BC. And comments or suggestions?
expobronc
HA! thats flex?? Lemme show you how we do rock crawlin in Iowa! you crazy flatlanders!! LOL (thats total BS and scarcasim you know) ;D
SC74
Now that I'm a Contributor .....
SC74
trophybass said:
Hey SC is that your exhaust or a driveshaft dangling down there?
Thankfully neither... it was a stick.
75
Speedwell TN
ok guys, lets us all know what you have done to your trucks in order to get all that movement. esp ineterested in type of leaf springs and radias arm work. thanks~bill
Steve
Grand Junction, CO
I'm running pretty standard 10 leaf spring packs on the rear, and inboarded the shocks. On the front, I have a wristed arm, rubber bushings at the frame end of the RAs, and long travel shocks & hoops. The wristed RA and long travel shocks make an amazing difference in flex. And, don't forget to install new longer brake lines from the frame to the axles or that'll be the limiting strap until it breaks. %)
Soft springs
Stock shock mounts
Uerathane bushings
Steve
Grand Junction, CO
Broncobowsher, what trail is that? Maybe I should load mine up and head down to AZ for a weekend? (after it cools down this fall)
md_lucky_13
Idaho
This looks like a thread steal!!
The poor guy asks about his flex, and suddenly everyone chimes in and shows off their own flex.. For Shame. For Shame....
On a side note.. This is with 5.5 inches of lift from Wild Horses. I am not a big fan of blocks, and anyone that says that 5.5 inches is too much arch to get a decent flex is out of bounds in my opinion.. I think one of the greatest areas of improvement is by going with a taller spring.
Just come to the AZbronco stampede this march. We will be running this trail again (upper terminator I believe)
SC74
Broncobowsher - What front bumper do you have? I'm looking for something like that - did you fab or buy? Thanks.
As for my flex ... not quite as impressive as the others, but it's just Duff's 2" with add-a-leafs (duals on all 4 corners - not hoops though.)
