The coolant recovery bottle can't really cause or fix overheating. Except inasmuch as it keeps you from loosing coolant like an open system allows.
It's just an overflow container, as a pollution control and coolant retention device. Keeps the toxic anti-freeze out of the environment and keeps you from having to refill the radiator every week.
The correct style of cap is a must for it to work at all though.
So while you can experiment around with it (not a bad idea to fiddle with peripheral stuff) it's very unlikely to help with your cooling issue of the moment.
Since it worked fine before and runs hot now at higher speeds and loads (but not at idle apparently) then you have to track down what changed. Internally or externally.
Presumably you'd been driving it in the hot weather already without trouble before this, so it should not be an external problem like weather.
If you did not add a bumper, winch, or lift the truck higher, or install an incorrect fan (hard to do with an Explorer setup I believe) it really should not be an air flow problem at this point either. It's good that you found the failing fan clutch of course, but since it did not help then air flow seems not to be suspect.
Unless something is blocking flow, or the aerodynamics of the vehicle have changed.
So tuning or coolant flow would be next on my list.
I don't remember if you checked the timing, but that would be next on my list. Not just the base timing, but how it advances at different loads and engine speeds.
If it's not linear and does not advance correctly due to something wonky in the distributor of ignition control module, this would cause the engine to produce more heat.
If the belt is slipping, pump is failing, or hose collapsing, this would make it harder to evacuate the heat.
It might all be new, but something changed so you can't ignore anything at this point.
Still about all I've got. Just waiting to hear how those tests go before pulling some more hair out thinking of what this mystery problem could be!
