Knifty 2 Build Thread
Mar1ne
Mar1ne
Sierra Foothills, CA
Picked up an American Autowire harness and Dakota Digital dash the other day. So far it's fairly straight forward as far as the wiring goes. Looming everything with Tesa tape.
I'm having some trouble with my heater cables not working properly. Lock the clamps down and nothing moves. Keep it loose enough for some movement the cable just slides through when you push/ pull. Not sure what the solution is.
Flaming River column and wood grain wheel in. The stainless column cover from Duff doesn't fit 2" column so that goes back on the shelf.
Mar1ne
Mar1ne
Finished up the AA harness except under the hood. Mounted the computer. Attached the ceramic coated JBA headers, harmonic balancer, new cam/ crank sensors, Centerforce clutch, and did the mod for the clutch equalizer bracket.
Header touching the fender well... I suppose I will pry the well out away a little bit, it's probably 1/16" from the tube.
I mounted the AX15 transmission and that went seamless. I have the pigtail with two wires, black/ black with grey stripe for reverse lights. Can someone tell me how to wire that into the AA harness? I have a pic attached of the three wires available (12v ignition, back up lights, and brake light switch).
I'll be working on the serpentine next. I found out that the water pump pulley is not available aftermarket so I reached out to Sanndmann3 and he has one on the way (thanks again). I am also in queue for EFI guy to rework my harnesses and should be coming up in the next month or two. I still need to do a lot, but on the downhill slope. Brakes, cage, measure for Tom Woods driveshafts. Hopefully done by December.
Mar1ne
Mar1ne
Harness is off to EFI guy, in line for a cage from Virga Customs, waiting on some miscellaneous engine parts. Finished the dash knobs, ash tray, glovebox door. Transfer case went in, cut the tunnel for the B&M shifter and JB Fab/ WH twin sticks.
Next:
serpentine
cooling
fuel lines
exhaust
Mar1ne
Mar1ne
Currently working on heater hoses and fuel lines. Dash is complete. Unfortunately I assumed the CD player slot was the correct size, but it's too large and leaves gaps on the sides. I will need to make a plate to mount to the dash and then the CD player to it. Oh well. I did find this digital media player and will try it out. It's a Pioneer SPH10BT. Has a phone mount built into that rotates 90 degrees to allow horizontal/ vertical arrangement. The mount folds down and into the unit, which will be the only way to pull the center heater knob. I wanted something with a screen up on the dash for maps.
I also need to do a little adjusting and heat/bend the twin stick. As shown is rear high.
Mar1ne
Mar1ne
Harness is back from EFI guy and it looks great. I also got a few items from Migs that clean things up under the hood as well. I'm finishing up wiring under the hood and will run EFI hose next.
Roll cage is done and will go to powder coating this week. I still need to do track arm riser bracket, brakes, cooling, and throttle cable. I'll be running a bikini top mostly that I'll get from Wildhorses and have a local upholstery shop cut to size and either add button snaps and I'll add the male ends to the cage or do the velcro straps in the style that top already has on the middle.
Mar1ne
Mar1ne
Finished the main wiring harness and battery terminal connections and surprisingly everything worked, except the heater which I forgot requires a ground from the blower motor. Easy enough. The rear view mirror even dims as it should when I shined my flashlight into it. Wipers are unsynchronized. Makes me think I should've got the switch, but it's an expensive price tag for aesthetics.
Cage back from powder coating in a 1 day turn around which is always nice. It went in easy with padding around the feet and a guy on each corner. Underside 3/8" plates on each foot. One LED light up front that's wired into the under dash courtesy lights operated by the headlight switch.
I still need to wire in the engine harness stuff under the dash and then start finishing up under the hood with power steering, brakes, cooling. Then figure out what muffler, 2-1, would work well. I had dual flowmaster 40's on my '66 and it was fun at first when I was running around town, but not so fun on long trips and trying to talk with a passenger.
Question: Can I start/ drive to the muffler shop (10 miles) with open headers (ceramic coated JBA) and a newly rebuilt explorer swap before any break in?
Mar1ne
Mar1ne
Saginaw pump went in easy enough. I ran the lines to avoid the brake prop valve and brake lines. Not the prettiest, but it works for now. Measured 86.5" for a serpentine belt and found one 85 7/16" that works. Installing a WH MOAB power brake unit and making the rear to front line.
Still configuring the VHX gauge and the last few wires from the engine harness under the dash. I picked up some WH mats and measured/ cut them around the roll cage. The bolts were kicking the mat up around it so I got some button head bolts and that helped lay it down.
Kicker 6.5" in a select increments centra-pod up front. Working on making some rear panels with a sheet of 1/8" 4'x8' aluminum and coating it with raptor to match. Maybe two 6x9's behind the front seats and a kicker 8" in a custom box behind the passenger wheel well.
This week: waiting on the radiator and mustang hoses, figuring out air filter mounting, throttle cable, driveshafts, exhaust, heat/bend twin sticks
Mar1ne
Mar1ne
Air filter fitted. I'll need to upgrade to a better filter soon. Throttle cable bracket from Jsmall en route as well as a Lokar cable that will hopefully work. Cooling system done minus an expansion tank thats on the way.
Connected the computers main power wire, put a few gallons in the fuel tank, and primed the pump with key on a dozen times, no leaks, gauge reads 39psi, dropped to 20 over 24 hours.
I have some 1.5" hook and loop (velcro) to extend the WH bikini top. My roll cage B pillar must be further back than my cage I had in my '66 from the same builder, slightly different design. The velcro worked out of the box on that one. I'm going to add snap fasteners across the rear section while it is taut, remove the edging with a seam ripper, remove the additional canvas fabric and sew the edging back on (hopefully).
Mounted a fire extinguisher under the driver's legs and mounted the centrapod up out of the way.
Mar1ne
Mar1ne
Mounted a 3"x9" expansion tank and did the sliding glove box hinge mod. Working on extending the velcro straps on the top now.
I shimmed the passenger rear body mount with two 1/8" washers that I think were extra in the 1" body lift kit. That lifted the rear up to get a better sloping line down and closed the upper rear door gap. It looks much better now from the side. I will shim the door back with 1/32" shims to split the difference and I'll be happy with the door gaps finally.
Mar1ne
Mar1ne
Rampage soft top fit well. Directions leave a little bit to be desired. Sent it to a local exhaust shop on the tow truck on the rainiest day of the month. 2-1 with Magnaflow came out nice.
First start at home fired up immediately and came up to temp. Threw a code for coolant sensor which I realized I had one for a mustang. I bought a VeePeak OBDII scan tool and OBD Fusion app and the ACT sensor was reading 250 degrees immediately, which then caused hard starting. I have the block sensor with my Dakota dash so I knew there was an issue with the computer's sensor.
Took it for a ride around the block and had some bump steer, which we knew was probably going to happen. Installed the track bar riser last night and centered the front end while I was at it.
Current problems:
Transfer case popping out of gear. I can push the rear shifter with a finger, so I'm assuming this is a detent spring issue which is easy enough to solve.
Running rich. Does an initial startup with EFI require some driving for it to learn it's air/fuel ratios?
Fuel gauge not working. Dakota gauge reads EEE under both Ford settings. I tried each setting with and without the ground and still couldn't get it to work. The American Autowire kit comes with one wire for "Fuel Gauge" connected to the sending unit, sending unit grounded, no reading. If all else fails I can set it manually.
Throttle cable. I have a Lokar with a spring I made to go over the cable at the throttle body. It's not nearly strong enough for a good return. Unfortunately I didn't get the original Explorer cable and they are nonexistent online. Anyone have an extra I can purchase?
