Large Case 1g Alternator Purchase - Help!!
TK1791
Boca Raton, FL
Can anyone provide me a link to purchase a Large Case 1g Alternator? I would prefer 100amp. I've only been able to find them on JeffsBroncoGraveyard, and I'm just looking to compare amps to cost.
Thanks.
TK
Yep.
As much as I like Mean Green products, and Wild Horses as a source, if you're not able to swing the $300+ for that one, check with them to see if they can get you a standard, non-supercharged version for less.
If not, late-seventies LTD/Torino/T-bird with 100 amp alt. Semi-common part number #7705
You might find variations, depending on the clocking of the connectors. So there might be a "7705-12" or a "-9" etcetera, depending on what clock position they used.
Steve83
I was shocked when I found one on this '90 E150:
I was getting Ryan a Saginaw for one of his Broncos, and it took us a while to figure out what I was looking at. I was confused because it only has 1 small wire & 1 large, and the VR was hidden under the lip of the core support.
Available up to '91 on all the old style engines (pre-mod motor in other words) in the vans.
100 amp'er. Good find.
That reminds me, just why is it that these are considered a better unit to be used as an on-board welder? Is it that you can get more robust industrial strength components for them? Or that you can buy a specific regulator more suitable to welding needs than you can get for the internal regulated versions?
Or what?
I can't imagine anyone installing that instead of a 3G.
I can imagine it. Not because I would anymore, but because until recently, I would have. I was a big fan of the standard externally regulated alternators for a long time. And I'm sure a lot of others are as well. They worked fine, were easy enough to diagnose, and were what came with the vehicle. That last part makes it easier for the uninitiated to wrap their heads around keeping it the same. Not everyone is a student of the modern changes wrought in the automotive industry in the last 40 years or so.
And the old style didn't have the stigma of being unreliable (undeserved as it now is) with internal regulators burning out prematurely.
Granted, that's a throw-back to the early '70's when every one I knew with a GM car or truck had premature replacement issues with their alternators. While everyone I knew with an older, externally regulated alternator did not have such issues.
Kind of like the thinking that electronic ignitions can't be good because they didn't come with my car and we don't understand them. And here again, the early GM HEI's had longevity issues too, but that was pretty much fixed decades ago. Still, it's the old "Black Box" fear creeping into the psyche. It's different so it must be bad.
Kind of like the kid in the video saying "A Chevy motor would never have done that." when they took the valve cover off of a Ford engine and it had sludge in it. Sure, a Chevy would never do that.... %)... Right. I nearly threw a hammer at the TV when I saw that. Couldn't believe whoever made it would allow the old "Chevy vs Ford" crap to creep into the light of the modern world.
As you can see though, some of us don't go easily into that light. We go kicking and screaming all the way.
Besides, they were cheap. And you didn't have to actually "think" about it. Just bolt-n-go, so to speak.
