Not what I meant. The two alternator styles use entirely different connector designs, so they're not swappable in that regard.
Because they do use the same wiring scheme however, it's a simple matter of cut-n-paste, so to speak.
I'll try to find a pic, but the choices are either cut your old connector off and attach the Orange wire (and the White w/black wire if used) to the new style connector and plug it in.
What I usually do, and I think most who've done the swap have done, is to simply disconnect or cut the original alternator harness and create a new one. That's a no-brainer if you're going with a new harness anyway, as the ends are not terminated until you do it. With an original harness, it's still easy to modify, you just have to think it through a little bit so that everything functions properly except the ammeter.
And speaking of the ammeter, anyone that upgrades to the large case 1G, but stays at the lower range of 70 amps or so can still use ALL of the stock wires, including the Black w/yellow charge wire and ammeter. You still have to add the new style plug of course, but everything else stays stock.
Once you get into the higher amp units though, in the 90 amp and above range, that goes out the window and you have to use your own charge wire like this:
http://www.wildhorses4x4.com/product/Battery_Charge_Cable_AMG_fused
That handles the extra power and then some, but completely bypasses the ammeter. So that's when you go the voltmeter route.
