Lengthen column shifter rods?
Stutsmo
I put a 2 inch body lift on my project Bronco. I am trying to hook the transmission shifter linkage up. I know I have to lengthen the linkage but I am unsure where to do it. Should I lengthen it so they have more drop, or lengthen it so that they are longer( add more thread )?
Does anyone have any pics of how they extended thiers?
Stutsmo
Stutsmo
Over 60 views in 24 hours and no "great advice from the helpfull members here"..... Guess I'm on my own for this one..%)
377
The Bluegrass State
Haven't done this yet but, I have been looking at the doing the same thing. Wild Horses sells an adjustable shift rod. Not sure if this will help with your question. If it does share how it worked out with us when you're done.
doghows72
I don't have any pictures but I cut and lengthened mine right at the steering column. Just added a length equal to the body lift. Hindsight I wish I would have used a sleeve vs just butt welding a extra piece or rod.
I would probably do the rod, grind it smooth and then sleeve over it with a piece of tube. It would be way easier to take the rods out and do it on the bench. My engine was out at the time so I just climbed in and got it done.
You can attempt to adjust them, which actually works some of the time.
But with 2" or more you usually have to resort to what doghows did and literally lengthen the rods by splicing them.
I like the sleeve idea too. If you're a talented welder (or know someone) then I'm sure a butt-weld is sufficient too. But once you start modifying stuff like this, I think a little overkill is called for. So sleeve it if you can.
