let's see your broken parts
73stallion
Eugene, OR
trying to explain to mom about axle wrap and what kind of things it can break. i did a search, only found a few pix. let's see the things you've broken (or links to others) due to axle wrap. ie leafs, perches, whatever....
av bronco
Palmdale CA
The first mod I did was traction bars so I havent broke any springs but...
bax
Old Member
Talk to BMC69 he is the king of axle wrap and breaking stuff.
Viperwolf1
electron whisperer
I can attribute all my broken parts to incorrect angle on the accellerator pedal.
bmc69
Snicker. I have a shelf in the office full of pieces..right next to the one with trophies and awards. I'll have Judi take a pic.;D
kb6677
Right hand side of shop rag pile you will see a ds., along with the pinion output from the rear Tera60 housing that met an untimely death before we put a traction bar on the white eb.............The other parts on the shop rag are fall out from a toasted 357 with a broken valve that went south, broken bumpstop that got ripped off,a fairlead that got rapped by a bfr-"no, you're fine, it will clear, come on up"............., steering arm which was broken due to design flaw on setup, also changed and no breaks since the change :)
You know that was an expensive shop rag when you consider the $$ spent to replace/upgrade stuff!!!!!!! Oh well, another "deal" I wont be adding up :)
bmc69
This here picture illustrates an 'upgrade'. I was proud of this upgrade at the time and had high hopes for its future success. However, it was not long after that I was edumacated on what 'upgrade' really means when yr 500 ft-lb engine is trying to turn 4 locked 39.5 IROKs with 4 psi in 'em..
Upgrade: The process of substituting larger, heavier, andr stronger components for weaker ones with the intent of making the 'bangs' louder, the broken parts larger, and the consequences on the pocketbook more severe.%)
The upper shaft is a Rockford Extreme Spline..the lower a standard 1330 shaft that has been trail-repaired once already.. One of those $175 Extreme spline ends is down in the valley next to the ole Rabbit Run at Paragon..it got pitched too far to find it when it let go.
Things like this H-yoke and the 1350 9" diff yoke, for example...
Or the ends of the driveshaft..like this. (Yes..got a call from GQ macazine right after I posted this one the first time..:p )
bmc69
I don't have a pic yet of my rear springs..but as soon as they are out I will lay one of the old 5.5" springs next to a new one. Axle wraqp has taken all but maybe 1.5" of the lift out and they are friggin practically flat with no arch any more...my rig looks like it has about 1000# of concrete in the back..
crab
Hoping I don't have to add to this topic today. My bronco is sitting in a buddy's shop down the road. I've had a slow leak in my cooling system and boiled over on the last trip out requiring about 2 gallons of water on the trail. Temps have been in the upper 20's here at the coast these past few days (that doesn't happen very often) and I don't have a very good feeling about what I'm going to find.
todd.gorman
Ceyzerieu, France
Here's a typical one... running up a bouncy 30 degree incline :eek: Of course it took out the driveshaft yoke as well when the u joint gave....
KyleQ
I killed the D20 on my first trip out after the 1 ton swap
I took the teeth off a MM lockout in my pickup
I've killed my lots of u-joints in the pickup with the D44/D50 hybrid, PowerLok and 34" LTB's. I wheel'd it stupid hard, getting the front end airborne quite a few times. The last trip out I let my brother wheel it and he killed one Spicer joint that I had full circle snap rings on with a chromoly outer and then after replacing the passenger side he blew up the chromoly outer on the driver's side.
mango
Sarasota, FL
D44 with new PowerLok, broke this new u-joint at Hollopawlooza. It made a nice loud pop when it broke. Thanks go to fellow members that had necessary tools to fix at camp. I try to packa llot of tools, but jack, stands and welder were not in my tool box.
I was lucky in that the ujoint was the only damage. No problems getting the axle out of the knuckle.
Upgraded to a solid u-joint so that I can break other parts too.
