Leveling kit on a Sasquatch
Crhawkins79
Got a question for you guys? I am about to be getting my new bronco and the salesman where I ordered told my that I do not want to install a leveling kit on a bronco with Sasquatch package….. any of you guys know why that may be? Just curious.
Thanks,
ep67bro
Bronco Junky
Easton, MD
Not really sure why. But I dont think the SAS broncos really need them. You do have to make sure that you get the correct lift for the SAS as the struts are different, than standard broncos.
WILDHORSES
USA
Just finished a perch collar lift on the 2 door. Drove it stock suspension, added some bumpers and winch after about a year. Usually didn't run the spare so it sat a little high in the rear. Once I put the spare and high lift on it was very level but noticeably lower (maybe 1"-1 1/2") all the way around. That's why I did the lift. Pretty much put it back to stock height with the added weight.
So back to the question why the dude would say don't install a level kit. Probably have to ask him but could be front end geometry change or some other thing he doesn't like. If I do a level kit on an SAS I'm more inclined to do a perch collar than the spacer. Just a personal preference. Spacer lift is easier and can be done quicker because you're not taking the strut apart to install the collar.
That's my .02
Jim
okie4570
NW OK
I did about 2 months ago. Took 1.5 hours. No more nose dive, looks 1000x better.
okie4570
NW OK
Thanks,
Post leveling pic finally lol.
Teal68
Inlet Beach
I did the RC level kit on my SAS. Same as Okie mentioned above with 2 spacers up top and one at the bottom. I put a winch on the front and noticed it dipped quite a bit. Once I added the level kit it got it back to exactly where it was originally.
Now I've added a heavy bumper to the rear and feel like I may have to add a spacer in the back! Pic with all three Broncos is with level kit up front with plastic rear bumper. Pic of 2023 Bronco only is after adding a steel rear bumper.
