Lil bama princess ripoff thread
bmc69
As some have noted..
1. Fule line from the pump is connected to the carb spacer vacuum port.:eek:
2. Carb fuel inlet is connected to ...the carb bowl vent. :eek:
3. Carb appears to be a Carter YF....later model from a 240, 250 or 300, maybe?. Carb is not connected to any throttle linkage either. (Not that this would matters since the thing would never run anyway.:p)
5. Vacuum inlet and outlet lines on the fuel pump are connected together; no functional wipers on that things.
6.There is a "T" in the maifold vacuum port. One line appears to be just open..the second one appears to be crimped off. The '67 EB 170 would have had only a single line connected to that manifold port.
Viperwolf1
electron whisperer
5. Vacuum inlet and outlet lines on the fuel pump are connected together.
Hey, that's 90% of the way it rolled off the assembly line.:p
jim3326
Appleturkey
I'd bet a dime to a dozen it's his POS work, Looks like he rhinolined over the mud-n-crud on the frame by the front leafspring hanger and coated the radius arm nut and washer, also looks like the front spring has some splatter on it. Passenger floor pan looks like it was coated then painted.
I would LMFAO if he was to try and start it. It would hydro lock after about 20 revs. just pumping raw gas in it. It may even self destruct if it starts on the first couple of revs:eek:
Jim W.
bmc69
The listing does not indicate that it runs.
It is clearly...very clearly implied that it does. "Restored"....and brand new engine parts, like fuel pump and starter, listed.
bbow
Ozark, Alabama
I borrowed some of your observations broncobowsher and submitted a question. Hope you don't mind.
Dear tnab77,
Butchered quarters.
Correct vaccum fuel pump but not hooked up to the wipers.
Open vacuum port on the carb.
Missing vacuum advance.
One of the 2 wires for the reverse switch unplugged.
Kinked heater hose.
Wrong doors with wing window bolt missing.
Windshield holding knobs missing
Holes in doors for speakers.
Fuel Line connected to the PCV.
The only thing possibly legit about this listing is the VIN tag that could have been acquired off one of the scrapped vehicles. Fraudulent listing according to ebay guidlines.
Dear bbowisbuff,
thanks for looking
- tnab77
bbow
Ozark, Alabama
I reported his listing as fraudulent thru ebay which is basically useless. I had no luck with my battle with ebay before. I thought once his wife divorced him that he would move back to Indiana and go away. Guess he's just gonna keep screwing people till someone "takes care" of him.
1sicbronconut
Here's what I asked him. "Just wondering about the doors they seem to be 68' or later doors, 67' doors would not have that style of inner door handle. Are the window frames welded or bolted to the lower part of the door? I've got a 70' that was sold to the goverment and have always wanted a military Bronco."
I received a answer to my question, I wonder if he know's that you can't really swap 68' doors onto a 67' tub without some major work? "they are bolted, and they are not the true doors when it was purchased from auction i was told it came with no doors as did many of these military vehicles thanks for looking" Should ask where the vin tag is located. Someone else take a look at the door window frames sure looks like they are welded on to me??
riverbum
tallassee
so, where, in Alabama, was this ass clown residing? i live near montgomery and don't want to get ripped off buy him
Mono
If he is honest about the broncos he brings to the auction block, there is a market for exactly what he puts out, and he would be very sucsessfull doing so. Not everyone can afford a resto quality bronco in the $20k-$30k price range. If you wanted to get into a bronco for $4,000-$7,000, he has a decent starting point. Something that looks decent as a driver, but needs a little work. The problem is when multiple people start bidding, and they get excited about something that looks good in a picture, and sounds good in a description. The bidding can get out of controll, and someone is left with a misrepresented bronco at a inflated price. He starts every auction at $0.99. The buyer with the final bid also needs to take some responsibility for how they came to make that winning bid.
I have zero problem with the quality of the workmanship he does, as long as it is clearly represented as built. From what I read on the forum, this is what isn't happening.
Mono
bmc69
Go stick your fuel pump output hose in to your PCV vacuum port, turn the engine over.....and then report back to us with your freshly revised opinion of that azzclown's "workmanship". ;)
Mono
Finish reading the sentence
John Monahan
320-761-5077
