- Nov 28, 2011
- 842
As many of y’all have seen in my other threads, a sim me bearing replacement has turned into a full on rear end rebuild. So I thought I would start another thread to clear up some of my questions and to ask for advice.
I have 35s with a 3.5” SL and a narrowed HP D44 going in the front.
1. I am planning on going with a limited slip carrier and 4.56 gears in the rear and then locking the front. My Bronco is going to be mostly street mild trail (for now). Thoughts on this setup?
2. My axle tag shows a 8.7” ring gear. Will I have any problems with swapping that over to a full 9” limited slip with the 4.56s?
3. I plan on getting one of the third member rebuild kits from the vendors as well as the gears. And then taking it to a shop to have it put in.
4. Pinion yolk. Upgrade? Leave stock? Anything else I should do to that area while I’m in there?
5. Spider gears? Does the limited slip unit completely take the place of the spider gear setup or how does that work? If not should I be looking to rebuild/ upgrade while in there?
6. Lastly, advice or thoughts or things to watch out for while doing this. Please feel free to explain it like I’m five. I’m learning as I go here.
Long story short I’m building a street/mild trail rig that I want to overbuild slightly for that application. The first part I’m tackling is the rear ended
Pics attached because everyone likes pics.
