Linear vs. Variable rate springs
rhino2104
I did a search and found the basics but I was wondering what would be best for a Bronco spending most of it's life on the road (75%-80% ). I keep finding contradicting data saying both handle off and on road better than the other. I'm looking for pros and cons of each.
Buldozer
Bronco Virtuoso
God's Country
I run the 5.5" lift variable type coils (tight wraps on one end and wider wraps on the other) and they seem to perform great on and off the road. The old stock springs had uniform wraps from end to end and they rode terrible.
TN1776
I am very happy with my WH variable rate coils. My Bronco is by far the smoothest riding lifted 4x4 I've ever driven or ridden in, both on and off road. And the flex is awesome off road.
A linear spring rate (a low rate at that) gives a nice ride and great flex. But in the turns... lets just say you will probably be the slowest one on the cloverleaf for any given sanity level.
The variable rates tend to be more road friendly. For the same working spring rate (comfort on a flatish road) the variable will handle better. In a turn the outer spring will load up. Since the spring is variable rate, the added load will move to a higher rate and not compress as much. The inner spring will unload, transition to a lower spring rate and not push the body up as much.
There are tons of different spring tunings which can cause vast differences in the performance of the springs. A really stiff linear spring (old school Rancho) will flex so little that it would be rather sporty to drive compared to a soft variable spring.
Now with as much street driving as you state, you probably are not looking for as much of the trail super flexy suspension that 90% of us on the this board are after. Many of use are willing to accept signifient compromises to the streetability of the rig for offroad performance and still consider them very acceptable for street use.
Come Monday, call up a few of the venders and pick there brains as well. Be sure to state a couple of times the amount of street dirving you are after. See what you get htere as well.
rhino2104
rhino2104
Thanks. I will be sure to call some of the vendors on Monday if and when I get the opportunity.
HoosierDaddy
The biggest issue I have read about is the variable rate springs settling too much.
I think that is one of the reasons Chuck at BC's uses a linear rate spring. the softer coils of a variable rate will begin to sag , and from what I have read , it only takes a few months sometimes.
Obviously , Chuck is selling a product , but he has a good reputation for making great products that work as they are supposed to.
This sums it up ...
http://classicbroncos.com/forums/showthread.php?p=1370435#post1370435
