Oh, i guess you have to use the advance mode. maybe next time i'll read the directions!
I'm going to use Peel and Seal from Lowes on the floor of my sleeper. VERY cheap but make sure to use a heat gun to apply it. http://www.ratrodsrule.com/forum/showthread.php?t=3226
The pic is the edead. I've been using a medium/coarse roller for the last two coats but it's still a pain. Spraying has to be the way to go. Oh, and I don't think 1 gal. is going to do it. Getting ready to order another one so that takes the cost up to $100 for 2 gal vs. LS's $150 for 2.
I just sprayed LS under my bronco it was easy and looks great.
How big of a compressor did you use?
Here's what I found on the driver's side. Small holes all the way across the seam. Not sure why it's raised in the middle but looks like it should be easy enough to cut out and replace.
