dhendriksen
- Aug 2, 2009
- 90
So I’ve got what I believe is a 2100 on my 302, and for the most part if runs great! There’s a couple of little things I’m trying to solve though.
The first that I’m hoping you all can help me with, is what I believe is the high idle and the choke. Here is how the choke plate is when the motor is cold. It physically won’t close more than this. Is this adjusted using the choke timing screw? Or is this a screw on the bottom of the carb under the diaphragm? Or somewhere else? You can see the vacuum diaphragm never has a chance to touching the choke - they’re a long ways apart.
PIC1 (choke): https://photos.app.goo.gl/4TfraPch4K1n6nHM9
PIC2 (driver side): https://photos.app.goo.gl/AtgvkhM3SmMUcNCc8
The issue I’m having is the engine fires RIGHT UP, but until it’s warm it will just die. The high idle isn’t set is my guess. I’m hoping if I can figure out how to get the choke to actually close, that I can then move on to adjusting the high idle.
Why did they have to make these adjustments so small and difficult to get to? LOL. Any pointers you can provide would be amazing.
