garberz
Bronco Influencer
Clean the back side surface of the ring gear, and mounting surface of the carrier with a file and check how much run out variance there is. As ken75ranger said, you shouldn't have more than .002" variance. Install it with a little tighter back lash and you may be good to go. I would do all that before changing the pinion depth. Once you start with the pinion depth, you have to keep correcting the pinion bearing preload. It could take hours. I mean hours more than you've already have spent.
Mark
Mark
