Having a variety of different differentials, and twin stick transfer case so I could pot power where I wanted when I wanted. A locked rear is generally more capable then 4WD with open diffs. A locked front in normal wheeling does nothing for you, only when you get to the limits does it shine. The locked front has plenty of draw backs (harder on shafts and U-joints, sometimes will plow straight even with the wheels turned for no good reason, nearly impossible to turn the steering at times as well). But for $20 that is a smoking deal. But if your carrier has too much wear and the clearances are not right it can act up. Mine (in a brand new carrier) worked great with 33s even in rocks, very capable of breaking U-joints (stock and larger).
