Should be fine. No it is not 100% water tight, so you might get some water in it if you spray the hose directly at it. But it still isn't going to fill up.
I'm planning on running 2 strips of aluminum L-Track with the moveable studs so I can move my seat up or back or take it put and use the little rings for strappin' stuff down.
Do you see any issues with mounting this storage box with those studs?
That would be a tough one to call. I don't see a problem with the stud part of the install, but depending on how wide the "L" bracket is the box may not fit between it. Also the box would have to either be on top of the "L" or under the "L" bracket(I am assuming the brackets will go from bolt to bolt in the factory floor?)
I bought one and noticed that it sat on the floor. Knowing that I would have water and dirt in the truck I set it up with 5 flat washers under each corner, works great. Now I can blow dirt out from under and water won't get under it and corrode it. Great box with a really nice combo lock.
I kinda thought that is what you were talking about. The box must use the factory holes and the holes are then covered by the box so it can't just be unbolted and stolen. So the only thing I can think to do would be to mount the box in the factory holes and drill new holes for your strips.
I got one of these a few weeks ago. Mounted it under the bestop fold and tumble rear seat. I had to space the seat up just a hair but it worked out great. The roller bearings are nice and the construction is great. Price seems right as well considering the build quality. I can post up pics if anyone is interested although mine are not so different from the other one posted here
Are the dimensions;24"x12.75"x2.75",inside or outside? The space under the seat is 25.75" wide and the outside of the box looks as if it fills this width.
The aircraft type seat tracks TAWL BOY describes are the ultimate seat mounting systems for an EB. The seat can be positioned anywhere front to back or turned to be rear facing in seconds. Removal is just as fast leaving the tracks for tie downs as he said. I think a steel strap wide enough to be secured to the seat and box on the inside with room for studs on the outside to lock into the track would work. The tracks would have to be installed further apart.
