I'm kind of in the middle of upgrading to new rims (already bought) and tires (plan to buy next month) and I may need to run 1/4 inch wheel spacers up front. I don't think I need to (I've already test fit the rims) but 1/4 inch spacers will widen things just a bit.
I've done some reading and searching on this subject and just need opinions and or conformation what I've found will work. Open to suggestions as always.
Wheels are Method NV305's 17X8.5 5x5.5 4.75 back spacing.
Tires are going to be 285x70's
I'm running disc brakes on my 74. Everything is 79 Bronco including the current wheel studs.
Current 79 wheels studs
Part # 610-219 Line: DOR
Thread Size: 1/2-20 Inch
Knurl Diameter (In): 0.625 Inch
Length (In): 2 Inch
Shoulder Length (In): 0.906 Inch
Material: Steel
Quick-Start Nose: No
Thread Handing: Right Hand
Wheel studs I found the I hope will get me the extra 1/4 inch
80's F250 and F350
Part # 610-277 Line: DOR
Length (In): 2-1/4 Inch
Shoulder Length (In): 0.938 Inch
Material: Steel
Quick-Start Nose: Yes Summit lists them as No
Type: Serrated Stud
Under Head Length (In): 2.25 Inch
Anyone using these? Worried the "quick start nose" is the extra 1/4 inch of the bolt.
Tim
Length (In): 2 Inch
Material: Steel
80's F250 and F350
Material: Steel
Type: Serrated Stud
Tim
