LORE Bronco restore
halogrinder
halogrinder
Houston
No updates recently because I took some time off of social media and teh internetz- so time for updates :D
First, my turdbox. I got the coyote/6R80/BW4418 loaded up in the superduty frame, hacked up the crossmember, did some weldy extensions and whatnot to make it fit.
the 2015? frame I got didn't have a gas tank, and so after buying two tanks (a 47? gallon that came from a long bed that physically goes from pinion to tcase, and crossmembers won't let it fit, and a 36? from a 2019 that is OF COURSE shaped different and won't fit the crossmembers) I ended up just throwing the main tank out of the 79 in the bed since i had sumped it already, anticipating throwing it into the 79's frame..... and well- it works but its temporary till I find the right tank. I want to find a 6.2 gasser 2011-2016 tank- it should fit without mods.
then, getting the BW4418 CV style out of the situation- I found a dude who makes these adapters to get a 1310 double cardan setup working.
The bed needed tabs welded onto the frame on 6 of the 8 bolts (and dennis carpenter replacement bed bolts don't work, stock or otherwise, so don't buy them :rollseyes: )
and then I had to drill holes through the frame as well- which fully sucked because it was on a weld transition. I chopped up some hockey pucks to shim the bed in two sets front/rear of the 5th wheel hitch, and cut holes in the bed so I can use it down the road.
sumbish fits pretty damn good, and I'm excited to get the cab on it.
20220215_143001-jpg.3121806
20220215_142956-jpg.3121807
20220215_142951-jpg.3121808
20220110_121900-jpg.3121800
20220110_121857-jpg.3121801
20220110_121853-jpg.3121802
20220110_121210-jpg.3121803
20220110_121204-jpg.3121804
fb_img_1642873901397-jpg.3121799
20220110_101530-jpg.3121805
Taaadaaa!
I threw some shorty headers on it, and some leftover stainless exhaust from the bronco, mig welded up (stainless welds funny)
driveshaft tossed in there.
now to wait for a lift to open up from one of my techs so I can steal it to throw the cab on there.
things that I see an issue with and I'd love some help:
1. the steering shaft on the superduty is a "triangle" style shaft. I ordered one off ebay to go to a 3/4" DD steering shaft and the "^" of the triangle is too narrow on the adapter. its also a "through-bolt-that-goes-into-a-slot-on-the-shaft" and the adapter is a set screw. I need help figuring out wtf to use for that.
2. the fking brakes. I have searched high and low and here's the situation. The ABS unit I'd love to delete, but currently am using it as a passive distribution block. front circuit is m14x1.5 bubble, and rear is m12x1.5 IF...... I need to convert those to 3/16 lines to get them to go to the master cylinder which is 9/16" front and 1/2" rear both 3/16 line. Ideally, I'd love to have -4 AN fittings so I can use soft lines to the master, but no one makes anything for adapters in that goofy size and configuration. I think I'm going to chop the lines off and re-flare them with 3/8-24 double flare and go to "T"'s, then -4 AN to the master. I don't know how else to handle that, short of finding a 6.2 booster and master and grafting those guys into the 79's booster mount. Thoughts?
3. rear driveshaft- The BW4418 is a slip rear. I THINK the SD was a one piece slip rear too, right? I was thinking of making a 2 piece setup, that way the slip doesn't have a chance of falling out the Tcase.
front-shaft-truck-jpg.3121809
halogrinder
halogrinder
Houston
Ok, now for bronco stuffs.
I got the cage installed fully, which let me put the Aux tank in. Lookin good.
Got the hood installed- it'll need some tweaks and adjustment. Also installed a gas setup to hold the hood up. I'll powdercoat the brackets so it'll hide better.
The truck just didn't want to start correctly still. slow to crank, even with the gear reduction starter, which led me to investigating what the hell was going on.
turns out the input shaft was juuuuuuuust to far to push the crank into the thrust. Thankfully it only ran for a total of about 15 seconds in this configuration, so I'm very sure the thrust bearing isn't hurt.
but- I'm glad I found the issue.
the Tcase and Trans came back out, I lopped a chunk of the input nose off, and re assembled it. Now, I have .008 in thrust on the crank (like when I set it up) so we're good to go. It also cranks over correctly now (go figure!) lol
while the tcase and trans was out, I got a HD output shaft from Wildhorses and a Toyota flange from Jess at Hi-angle. the flange didn't fit the seal- so a run down to the machine shop to huck it in the lathe, then on the crank grinder fixed that up.
Also decided to put a 1350 yoke on the pinion as well if we're gonna make the rear shaft handle the power/torque the engine can now produce.
20220111_180528-jpg.3121817
20220111_180203-jpg.3121818
20220216_161000-jpg.3121810
20220207_134734-jpg.3121811
20220207_121931-jpg.3121812
20220204_174633-jpg.3121813
20220202_173659-jpg.3121814
20220128_162146-jpg.3121815
20220114_181526-jpg.3121816
I couldn't help myself. I had to crank it up uncorked :D
I was feeling real fabricate-ee, so I knocked out the rear exhaust from muffler to tips. Safe to say that I got my quad and glute workout 😂 up down up down up down up down LOL anyways, really happy how it turned out and will send it out to get ceramic coated. Ran it for a while today to bleed the cooling system and it sounds freaking awesome. Overall real happy with what I got done today.
Initially I put the exhaust even with the back of the body- but the pipes looked like an afterthought because they were so visible- so I moved them to turn underneath the spring hangers....and YAAAAAAAAASS that's the look I was going for. Now to pull them off to get ceramic coated and reinstalled for the last time.
20220217_172333-jpg.3121819
20220217_172226-jpg.3121820
20220217_144500-jpg.3121821
20220217_144403-jpg.3121822
20220217_140058-jpg.3121823
20220217_135343-jpg.3121824
20220217_135335-jpg.3121825
20220217_133814-jpg.3121826
20220217_133041-jpg.3121827
20220217_132817-jpg.3121828
halogrinder
halogrinder
Houston
Few more pics.
Waiting on a few odds and ends- I think its almost time to put seats in it.
one thing I noticed, is I can't get the p/s to make decent pressure and/or bleed well.
The pump is putting a little bit of flow out, but not enough for steering to be felt.
I'm thinking the 30? times I took the got dam thing apart after powdercoating the housing is one indication that something is off/wrong....
I may just buy another pump and transfer the AN fittings I made to it and say screw it-
But i'll pull the control valve out and see if there's something there thats causing the issue. if not, I'm just gonna replace the damn thing.
20220217_180445-jpg.3121829
20220217_172442-jpg.3121830
20220217_172423-jpg.3121831
20220217_172358-jpg.3121832
halogrinder
halogrinder
Houston
Got the back seat installed
20220223_112433-jpg.3122015
This escalated quickly :D
I started at 2:30 and this is 6pm. not too shabby :)
Things to do (lol)....... plasma all the body mounts off, attach to the cab and level frame.... then weld mounts back on.
figure out wtf to do with the left side header and steering shaft. they finna get into a fight.
20220225_173213-jpg.3122016
20220225_154900-jpg.3122017
halogrinder
halogrinder
Houston
Whoo! what a week it's been.
so.
Day 1.
Threw some 37's on it.
figure out body mounts and what the hell I'm doing lol
Chop frame.
I realized my mistake mid-stroke on the frame chop and just had to roll with it.
20220225_173213-jpg.3122162
20220228_085917-jpg.3122161
20220228_122916-jpg.3122156
20220228_121926-jpg.3122157
20220228_121855-jpg.3122158
20220228_121746-jpg.3122159
20220228_121734-jpg.3122160
Day 2.
I welded in the frame mounts (re-used the super duty mounts and ran some poly mounts)
Welded in some frame horns to hold the front bumper and core support.
20220301_182322-jpg.3122164
Day 3.
Made exhaust and figured out how to make the rear tail pipe work with it.
20220302_182630-jpg.3122163
20220301_182303-jpg.3122165
halogrinder
halogrinder
Houston
Day 4.
Finalized the exhaust and installed a booster/master from a 6.2 F250.
Bled the brakes and it feels great!
20220303_175419-jpg.3122166
20220302_182637-jpg.3122172
20220303_175354-jpg.3122167
Day 5
mounted the pedal, worked on the wiring.
look.
MARS should be charged for war crimes on the wiring bullshit they sent.
They must've used 5-6 rolls of electrical tape to put this fucking thing together. Its ridiculous.
I have a ton of wiring re-do and clean up.
worked on the fuel system, got the 6.2 gas tank in the 6.7 frame, had to make a harness and replace the fuel pump.
You gonna paint up my radiator with your logo? better not suck ass at your business :D
20220303_175349-jpg.3122173
20220304_150527-jpg.3122170
20220302_182649-jpg.3122171
Started it!
Day 6
Welded up the fill neck to the size of the SD tank (like 1 3/8 vs 2").... found a fill neck hose, made a breather, ran -6 line to the fuel rail.
made a bracket to hold the Volvo power steering pump. Waiting on fittings.
made an emergency brake extension, need to make a little bracket to hold the anchor of the bowden cable onto the frame
20220304_182344-jpg.3122168
20220304_182336-jpg.3122169
halogrinder
halogrinder
Houston
you know when you wanna do the very best, and you try/buy/build the very best to your ability..... then nothing goes to plan like you wanted it to?
Enter TBP front seat brackets, floor pan and seatbelts.
What a cluster fuck. Nothing fit. Nothing.
No holes lined up other thank 3 out of 9.
I'm pretty aggravated over the situation but they're in
20220317_083902-jpg.3122513
20220317_083854-jpg.3122514
20220317_083112-jpg.3122515
20220316_170126-jpg.3122516
got the exhaust in :D
Looks good!
20220316_134916-jpg.3122517
20220316_133612-jpg.3122518
in the mean time I'm swooning over my truck!
I can't figure out a transmission issue -that isn't the transmission's fault.
the vehicle speed signal at 40mph shows about 4-5mph.
The total mileage driven in the PCM flashes every 10 seconds for 3/4 of a second, the Vehicle speed signal (calculated) becomes accurate.... and then it'll shift to 4/5/6.
the mileage goes away and it shifts back to third.
I'm convinced its a PCM issue so I have another coming.
20220314_114249-jpg.3122519
tasker
all knowing of nothing
NH
UNREAL! love, love, love this build! (both of them!)
fordfan
It is very frustrating when the components that are suppose to work together (seat brackets and to fit floor pans) and they are so different! It's something that always bothers me: The manufacturer goes to the extent of producing the part, but doesn't make it correctly. Why would you even make it if you know it isn't going to fit?!?!?!? ....and did they make it and never test fit it to the Bronco?!?!? ... Yes, I feel your pain! I really hurts when everything is finished and it's hard to modify the components to make it work....
halogrinder
halogrinder
Houston
Pushed the thing over to the alignment machine and straightened it all out.
For having the shit jumped out of it, it's most okayest in alignment lol!
We'll see what it does when I drive it.
20220401_165049-jpg.3122837
worked on the doors.
20220330_180700-jpg.3122839
20220330_174928-jpg.3122840
20220330_174917-jpg.3122841
20220330_174910-jpg.3122842
20220330_174842-jpg.3122843
20220401_160634-jpg.3122838
Changed the oil and made the power steering work lol
I did stupid stuff with the Unimog :D
20220328_113656-jpg.3122845
halogrinder
halogrinder
Houston
Been busy working a deal to buy a new property/shop for my business so I've been a little pre-occupied.
But, I have been working on this little ditty-
This is the working prototype- now i need to work on the model a little bit more.
Overall I like it.
see it when you want, hide it when you don't .
Finished up the doors. they are tight with the new seals, so let's hope they relax a bit. sheesh!
Put another water temp sensor in, because it shows 120 on the dash, and my sniper shows 180......
So I need to find a legit temp sensor that hits the right ohm values.
Bled the brakes and clutch.....
Sorta waiting around for Jess at Hi angle to get the rear shaft to me.
20220415_171916-jpg.3123082
20220415_171910-jpg.3123083
pretty cool what my ultra sonic machine will do with old parts. This door latch looks freakin brand new!
20220408_094410-jpg.3123084
That is looking nice. What kind of medium are you using in the ultrasonic device?
One thing we've found even with 50 year old latches. Once they look good like that, about 90% of the time they also go back to working as good as they look!
halogrinder
halogrinder
Houston
This is the truth. a little lube and presto change-o. I use an 80 gallon omega sonics US machine with Omega clean
halogrinder
halogrinder
Houston
ok now officially hung up until Jess gets me my driveshaft.
So, I redid the seats in big red since i still have no solution for it's shifting issues, and no one in the coyote world has seemed to run into this issue, nor has heard of it.
Yay me.
wired in tow/haul and shift up/down on a little switch panel, too.
Replaced the front vinyl that I put in from automotiveinteriors.com (which absolutely SUCKED, and didn't fit worth a shit) with one from LMC.
As you can see, it still needs work (this has been massaged way more to lay more flat) but really, it seems like you're gonna get a wrinkly shitty fit vinyl floor no matter who you get it from.
And, that sucks.
Anyways- mounted the windshield, got the bikini top installed, now to get the wipers sorted out.
20220429_165040-jpg.3123454
20220429_165017-jpg.3123455
20220429_163322-jpg.3123456
20220429_145502-jpg.3123457
20220429_145446-jpg.3123458
20220429_140123-jpg.3123459
20220421_135249-jpg.3123460
20220421_135225-jpg.3123461
20220420_110646-jpg.3123462
20220420_110501-jpg.3123463
.94 OR
Willamette Valley, OR
Love the work.
Hard to see from the angle provided. Did you change the angle on the aluminum angle for the front bikini mount? My old Kayline used steel and it angled back more like the windshield.
