lost turn signal flasher...
BoltBuster
I would think it would be in the fuse block but not sure since mine is a wire kit. Are you sure its the flasher? Check for a bad bulb you can get the same problem.
casadejohnson
Bronco Alchemist
I don't know if it changed from the 74 but mine is located under the dash just to the right of the steering column. Its just a plug that comes out of the harness. Its not mounted to anything.
hackyrat
In my 76 it also is under dash right of column. But as stated above check your bulbs first, particularly if it only flashes on one side or if you notice a front or a rear light stays on while the light on same side is off.
