EastcoastMike
Newbie
- Sep 25, 2019
- 20
My Bronco runs and starts fine, but the voltage is consistently low. It never gets to 12V, nor does it drop below 11.2ish. Very little change in voltage whether its running or not. I only noticed because I installed a USB outlet that has a volt meter built in. I confirmed voltage with a meter.
Any ideas what is causing this?
So far I've done the following trying to chase down the issue:
1. Replaced alternator.
2. Replaced Voltage Regulator
3. cleaned all contact points for battery ground wire.
4. Asked myself why I'm so concerned if it starts and runs every time I ask it to.
Battery tested good, but only had 11v. Truck has a Centech wiring harness.
There's no voltage drop-off after sitting for a week or two. Help me out, I'm stumped.
