LOWERING my Bronco
greatguy57078
greatguy57078
I hear you there my friend. With the weather we've been having I don't see much going on here for a little longer. I am going to rebuild my heater box this coming week though. Every day I go to work it has been in the single digits. I have to stop by the body shop one of these days and see what's going on with my chopped halfcab. Here is a little look outside the shop I was working out of last winter. Looks pretty much the same as my driveway. Hoping that some of the snow melts this week. It just might get above freezing for the first time in days!
behemoth
Just a status update that there is really no update.
The weather here is finally back to normal sunny and warm, but now all the yard work has to happen so the garage is not going to get any attention.
The truck will not make fabulous fords this year, third straight miss on this project.
There has nothing really been going on, still messing with inner fenders and the lokar shift indicator. Again not much of anything going on.
Hows yours? Is Dales up and running ?
Bill
greatguy57078
greatguy57078
I will have to email Dale and see, but I would think he is on the road by now. He was not doing anything really extreme other than the Mustang II IFS, and that was finished last year. It is in the upper 40's here today, and supposed to stay that way this week. Warmer weather is on the way, and I will make some kind of progress soon enough.
Speaking of which...what model number coilovers did you go with up front (QA1 right?)? I figure by the time I figure out which weight spring to go with I might as well look into that. I have another halfcab out in the yard that I have to finish tearing down also. Was nearly done when it was buried in a 5-6 foot snow drift. I can see it now, so that reminds me that I have to get that stripped down and haul off all the rusted/broken parts. Hang in there street rod Bronco fans. It will eventually come to life! ;D
greatguy57078
greatguy57078
Just a few more questions.... for now. I seen that you cut the holes through the A arms for the coilover front shocks. Were the mounting surfaces already there for the coilovers, or did you have to weld them on? You also said something about the diameter size being important on the studded end.
Could you elaborate more on what you had to do to be able to use these shocks? Are you satisfied with the 375lbs rate springs or would you have rather gone up to the 500lbs? I am going to be using the 4.6 DOHC engine, so that might make me want to go heavier if I go that route.
behemoth
First the lower a arms that I have came with a coil seat cup that would not allow the coil over to be bolted in. I cut them out to allow the coil over to reach the bolt. The QA1 coil over kit that I bought bolts to the stock shock bolt. This stock shock bolt is the diameter that is important, I guess some kits come with a larger bolt. The QA1s that I bought were for a stud mount mustang II and the 600lb kit is the one I recomend. The 375Lb in coil overs is to soft for the weight of the bronco. The front of mine weighed in at 1600 lbs and the 600 lbs springs are only two threads from the bottom with the arms close to parallel.
After looking at what pictures of Dales I have seen and looking at where I set my ride height they are close. With mine and the arms level there was no way that I was keeping the inner fenders. Just be prepaired, to cut them out.
I have also gone with different uppers, they are more triangular than the ones I purchased in the kit. these new arms just clear the upper coil mount and do not hit the wheels. I have also gone with the 1/2 wheel spacers as well.
All that is left is to finish figuring out the inner fenders and then see what other gotcha come up out of that. Battery, mass air, brake booster and master all come into play now with the raised inner fneders.
greatguy57078
greatguy57078
Update: the truck goes in to the body shop for the chop next week. The guy is always really busy but he does great work so it has been well worth the wait. I took "old Red" out from under the tarp that I had fastened over the windshield and bulkhead, and after sitting out in the snow all winter she fires right up.
After letting her sit and warm up for a bit, I just couldn't help but take her to town for one last romp as a 4 wheel drive truck. It was great fun, especially on one of the first warm spring days with everyone looking, pointing and waving. What can I say? I love the way those old cherry bomb mufflers roar in a quiet neighborhood! :cool:
Here is one last look before she gets chopped 3 inches and lowered at least another 4 inches. It will also get new uncut quarters installed, as well as something I have planned for the hood that will remain secret for now. I do plan on a front valance with fog lights and rear roll pan. Hopefully I will figure our some way to shorten the tailight section on the bottom. It just looks too long and square on the bottom corner for me. I will post some pics along the way of course, so keep rooting me on....I am going to need it!;D
greatguy57078
greatguy57078
Hey Bill...my A arms do NOT have this part that I have highlighted in RED. Did yours come that way or did you have to add these to allow to be bolted up to your coilovers? Just curious, as always!;D
behemoth
Those parts are for the shock bolt, my heidts arms came with them installed already. One end is threaded and the other is just a tube.
Nothing special with mine stock looking bronco on the outside, stock inside all 90's under the hood.
I was looking at a roll pan as well , but with the front bumper 7" off the ground I figure even a spoiler is not going to work.
I might shorten the bumpers.
behemoth
It will be rolling the root beer turd brown for some time. The funds are just not there to go any body work or paint.
The color choice is a 93 geo prisim dark teal poly. Really good looking color wth all of the bright chrome and wheels as well as the stock white hard top.
greatguy57078
greatguy57078
Well she is supposed to go in for the chop THIS week. We will have to wait and see about that. It has been quite some time now, but I am confident that THIS WEEK is going to be the real deal.
On another note, I found a better candidate for the street rod, as ol' red would have to have the rear quarters changed back to uncut.
The '69 I found was in a small town in the middle of South Dakota and had not left that town since they rolled her off the truck back in '69. It was an old service station truck, as you can still see the "Phillips 66" logo on the rear quarter panels. It is also a delivery version, as the bulkhead has no holes drilled for a halfcab, and there are no holes for a back seat to be mounted. I won't even mention how many miles are on this truck;D, or how little rust I found!
If someone is in the market for one of these "behind the seat" add on tanks let me know, because it will be removed by Friday. The bench seat will also go eventually.
Well, what do you think guys?!:cool:
greatguy57078
greatguy57078
Well ok....a few more pics!
Oh...and we pulled the top off for the very first time just the other day. Nice top other than where they wedged fiberglass insulation between the top and a 3/8" sheet of plywood. Crude but effective!%)
behemoth
Nice find, I like the bench seat option myself, now if there was only a way to get the bench here....
Is there rocker rust or some reason why they covered them up.
Very nice and I am sure you picked it up really cheap... lucky guy.
Bill
I guess I said I would drive it to fabulous fords, I just didnt say which one, 3years and counting.
greatguy57078
greatguy57078
Bill
Yes the price was right. I have not removed the covers he put over the rockers but he threw in a set of brand new rockers anyways! This is as "one owner" looking as they come for a '69!:cool:
greatguy57078
greatguy57078
If you're looking for the perfect bench seat for a Bronco (especially like my half cab)....you have to go with the Mustang bench! I can't wait to get the halfcab painted and this seat mounted in there! Great condition...look no rust!;D
behemoth
Well there is will and the way is the shipper. I like the mustang bench, but the dollars they go for is more than I have. You scored on that one as well.
I like the stock bench myself, recovered in something less painful in the socal sun.
Wired up my o2 sensors yesterday, will wire up the nss and backup lights tonight.
Still dinking around with the new inner fenders, adding a little mud to make them look less like I built them.
Someday.....
greatguy57078
greatguy57078
Hang in there Bill. Heck if you have a Greyhound terminal close to you that bench seat could be shipped for maybe $75 or less? Food for thought! I just have to spend more time working on this project and less time shopping for these deals! ;D
greatguy57078
greatguy57078
Well the day finally came. As I said before getting your vehicle in the door at this shop is half the battle. I pulled her out of the garage and snapped one last pic with her at regular stance. After bringing her back home we will have to set this baby down on that frame and see what she looks like compared to Bills creation. :cool:
I will be sure to stop by the end of next week and see what the "chop master" has accomplished. Pics will be posted. Three inch chop....here we come! ;D
bronko69er
EB Addict
Renton, WA
Yes, please take as many detailed pics as you can to show how the chop is done. I have several different ideas on how to do it but have not determined which route to take. I'm especially interested in what sort of windshield gasket or mod will be used to seal the windshield, and where the cuts and "re-joins" are made to the window frames.....
