LOWERING my Bronco
Heus33
Its been three days where are the progress pics?!?!?!
I'm VERY interested in seeing what you come up with for the front valance. I've been scratching my head on this for some time but just can't seem to see a good way to integrate things without it looking too hookie. Do you have a template in mind or are you going to start with raw sheetmetal and french in some fogs?
I wish I still had my spare grill to practice on...
greatguy57078
greatguy57078
Pretty much start with some old steel I have in mind. And yeah, there will be driving/fog lights. Patience it all takes time...hehe!;D
greatguy57078
greatguy57078
Ok this is what I am thinking, and would love to hear other opinions. I bought the above mentioned '69 delivery wagon. It has the bulkhead and no holes in the bed for a seat. It also has one of these aftermarket gas tanks that sits nice and neat right behind the bulkhead. What I was thinking was to leave it and use it for the main tank. I have a second bulkhead that I could bolt in behind the tank. Then I would make a cover that would fit over the top of the two bulkheads and fab a filler door right through the top of the cover plate.
Does that sound like a cool idea? I am not sure that I would feel comfortable riding just ahead of that tank of gas, but not much different than having a saddle tank right under the driver's side....right? %)
behemoth
Gas tank what gas tank I do not see anything but a bench seat ;D
The older trucks chevy and ford have tanks in the back of the cab, as long as it seals good and no fumes I would not worry about it all the time. the saddle tank is under you so there is not a large chance of it splashing or leaking on you in a crash. I guess I am getting old also with the efi you would have the pump close to the tank and hear the buzz of it. Although the weight balance might make it more front heavy than it already is.
Now if you eliminate the small rear main tank you can then move the rear cross member and adjust the wheelbase more as well as c notch it a bit more.
just some random paint fume induced ramblings.
behemoth
On the front valence, I keep looking at it and with the front bumper 7" off the ground as it is there is not a whole lot that anyone will see. I was planning on running a spoiler, but at this height I think the first dip speed bump it will be torn off. somewhere around here there is a pic of the front end on the ground.
greatguy57078
greatguy57078
The work has begun. I stopped in to show which mirrors I picked out for the project, and lo and behold....the chop has begun and he was grinding down some of the welds! It looks great to me.
We are now discussing whether to add length to the top of the halfcab, or to rake the windshield. My preference would be to rake the windshield to make up for the metal removed out of the center of the cab, and the mirrors I picked out would fit the angled corners very well at the same time.
I am thinking tip the windshield forward. Next cut/grind material off the bottom inside edge. Remove whatever it takes to match the angle between the top of the door and the back of the windshield. Then tack weld the sides and back (under where the dash pad would eventually be), then grind off the piano hinge along the front and weld that back in and grind it smooth. I won't ever be driving with the windshield down, and would no longer need the hinge for anything. Weld it all solid and grind it all smooth.
Am I missing anything? Is there a negative to raking the windshield and welding solid?
Tito
CB Fire Starter
Bakersfield, CA
Are you eliminating the vent window? I might try to extend the top before I reangled the windshield frame.
The more I think about it the more pieces that I can see that have to be reworked. Windshield frame, window frames, angles of the top, upper windshield flange, vent windows, etc. And although broncos are boxy, they aren't rectangular, everything has a slight conpound angle to it.
greatguy57078
greatguy57078
The vent window is already gone. There will be a small triangle piece welded in that corner to accomodate a '87 Mustang mirror (yeah keep it Ford!). Both front and rear windows will be 3" shorter (on the bottom on the rear window to retain the slight curve to the top of the halfcab window). There needs to be just enough (approximately 2.75") removed from the windshield frame to allow a small amount of rake to the top itself. No one said it was going to be easy!
bronko69er
EB Addict
Renton, WA
Thats exactly the way i was thinking, I'm probably not going to attemt the extra rake on mine, too much work.
behemoth
inner fenders going in soon, and a possible hood scoop and my new window surfers.
greatguy57078
greatguy57078
I wonder what would happen if you would run the wheel wells all the way back to the firewall and close that gap there. Kind of wasted space anyways...right?%)
behemoth
I looked at doing that for both sides and there are issues like the wiring, speedo cable, and ebrake on the drivers side that prevented me from doing it.
After cutting as much away as I did I realized that the stupid inner fender is an important part of the front clip structure.
For you though with that mod motor you may have to shape yours differently and make the engine compartment much cleaner than stock.
I was trying for stock in appearance to make it look like I had done nothing. the beads are an unfortunate need.
fenders, gas, pedal, brake lines and some small wiring. Then ebrake and lizzard skin then who know I may try and start it before christmas.
77bronco_ed
Looking over the postings, there are difficulties with the inner fenders. Do you still have the same hub to hub dimensions or was this changed with the modifications?
-Ed
greatguy57078
greatguy57078
I haven't got there yet, but should know soon. With the 4.6 DOHC engine, I am sure there will be some trimming. %)
77bronco_ed
After looking again, Since it is lowered the wheels are setting higher into the inners.
behemoth
yes that is exactly what happened lowering the truck put the tires into the inner fenders. I am running the 17s I do not know if it would have been as bad with the 14s that others are running.
Expect at least 3" of them, to go on the top and front edges, the rear is fine.
greatguy57078
greatguy57078
Well I stopped and took a few pics for those that have been waiting (as well as myself)! Looks like we may have to sacrafice the dash pad to see if we can get the windshield to lean back to bring the windshield frame into line. I would like a small amount of rake to the windshield, so we have to cut something off the bottom of the windshield frame to get the lean I want. This would later be welded solid as I have no future intentions of ever driving with the windshield down.
Another option would be to add a little length to the roof to bring the front edge forward to get it to bolt up. I will play with it and see which direction we go, but I have a feeling it most likely will be a combination of both. Sorry for the cell phone pics, but something is better than nothing...right?%)
For those you are interested in the technical data, we have removed 3" out of the back. I decided that I would just cut the original window to fit the new opening. I have a buddy from high school that owns the local auto glass shop. ;D
If Dale's calculations are correct, there needs to be aproximately 2.75" removed from the windshield frame in order to bring things closer into alignment. The overlap you see with the windshield frame is very close to 2.375" right now. It is best shown in the third pic. It will undergo another BIG transformation when this body is sat down on the lowered frame I have set up in my garage. If I have figured it right this truck should be right around 7 inches lower than the day it was built by Ford. Well....what do you think? :cool:
hartbronco
Powell River B.C Can
Just cut the roof in half and add a pice in to make the door window frame work !!!! And then you can keep the same angle as factory .
greatguy57078
greatguy57078
A few updated pics from Dale in Wisconsin on his project.
