LOWERING my Bronco
greatguy57078
greatguy57078
Thanks guys. With the economy in the crapper and coming off shoulder surgery (again), I can surely use a boost. Maybe after I heal a little longer and stop writing checks to the Bronco Connection, I can get back to work on this beast! :p
greatguy57078
greatguy57078
Yes sir. One rig that is very well done. Not sure what engine is in that, but a Boss 429 would be hot!
01Dudley
Knoxville
Engine
I got a good look at this thing at Columbus GoodGuys. Yes very nice and it made the Pro's Pick at Columbus. It had stock Bronco rails w/a mustang2 frontend(airride obviously) and was powered by a LS3 motor. We are working on a order for a guy in Texas right now who is using a LS6 motor in his Bronco. It will be 4wd and ready for the desert. What do you guys think about LS in a Bronco? Makes good power, good torque, light weight, small, and fairly inexpensive. I know it's not a FORD, but ......
phred
Earth
What do you guys think about LS in a Bronco? Makes good power, good torque, light weight, small, and fairly inexpensive. I know it's not a FORD, but ......[/QUOTE]
I personally think that all crossbreed engine/car combos are wrong. Keep the chebby junk in a chebby. If you want to go fast cheap run a chebby. If you want to go really fast run a ford period!
I was looking at LS1 crate motors last night in a catalogue and the torque and hp numbers were lame compared to a ford winsdor or 385 series engine of the same displacement and specs.
Chebby's are cheap that's why everyone runs 'em.
Stepping down of my box now and going back into may hole.
greatguy57078
greatguy57078
No way. Why worry about the money? You are already spending a boatload on a build like that. I personally think it cheapens the project as well as resale value by not keeping it correct to the brand name. I was watching one of those shows where they pull cars out of the junk yards and flip them. After seeing that one of the shop owners had to fight to be convinced to NOT use a small block Chevy in a classic Mopar, I would never buy anything from someone like that.
We go to alot of car shows every summer/fall. They have some amazing cars no matter where you live. Yes most old cars have the Chevy motor in them, but I think that's just going cheap where you should have stuck with the original brand.
The love of the brand by the owners and the builders always shows and is a huge factor in which cars I think are the best. NOT keeping it Ford? It's not gonna happen to my cars or trucks!
greatguy57078
greatguy57078
If you are going to race then money is a factor. But if you are going for the cool cruiser effect, I say leave it with the brand name engine/parts. If I was racing I would go cheap too and run Chevy, but then I wouldn't be winning so where's the benefit to that? :cool:
roundhouse
It's one thing if it's one of the old cars where a Chevy 350 will drop right in but putting in a ford engine takes days of welding and fab work
Which is most every ford from a model a to 40 coupe a 50 ford coupe even a48 F 1 pickup. A chebby engine drops right in.
But in a bronco a ford engine bolts right in
The ford engines lack power though
I've towed the same large boat on the same route with a 98 Yuckon vortec 350 and with a 95 bronco with the 351. And the Chevy felt like it had double the power and got better mpg
Same comparison with my 5.4 expy against the 5.7 tundra
The tundra had twice the power and uses less gas
In a custom show car mpg is not an issue since its not going to be driven much and you're not towing
One of the problems with your comparisons, you are using 2 different generation engines in the same comparison. The '95 Bronco is an old school engine that was basicly just carryover forever. The Vortec had a generation newer development, especially in the top end. Same thing for the Expedition (don't know what year you used) but that 5.4 was never that much of a hot rod engine. The Tundra was built for power. But telling me the Tundra got better gas mileage is a bit surprising. Usually the Tundra drinks fuel the most and the 5.4 is average. I wonder how the rest of the vehicle options (tow package) were speced out?
roundhouse
Tundra has the tow package
It's 2012. Expy is a 2004 4wd. But the 4wd expy is the same height as a 2wd.
Tundra gets 14 , on the same route the expy gets 11
behemoth
I pushed mine out of the garage today and took the hood off in prep for the return of the core support and inner fenders from paint.
I also cleaned the dust and dirt off of the seat, looked at the doors and hinges for the hidden hinge kit and am some what again over whelmed with this mess. Also cleaning the garage to allow me to think about working on the truck again.
Battled a transmission pan leak or adapter housing leak on the big one next to it so that may get in the way of the lowered truck if I have to pull the t case and fix that seal.
Hope the shoulder heals well,
Im having thoughts on no door windows at all, no side marker lights no wipers.
Have a wonderful day.
greatguy57078
greatguy57078
Hey Bill. Can I see which hinge kit you have? I think all my stuff is Lokar if I remember right. To be honest I thought about running with nothing more than the windshield along with a good roll cage myself. I would have saved a ton of money on the chop. That and how carefull I will have to be removing the halfcab every time, let alone storing it.
behemoth
My hinges are from haganauto.
greatguy57078
greatguy57078
Do you have pics or a part number? Just curious. I think I posted pics back when I bought mine but not sure how far back that was?
I have even thought of selling my door parts. I bought the hidden hinge...the suicide kit...the shaved door handle kit. My brother says I will only regret it and decide to do it again later on.
behemoth
I think the main difference is the spring loaded ball detent these are the hh2 but I believe he is not going to ,make the hh2 any longer. I'm going to install them just a mater of when. Since my build is now going to be painted I need to dot his one time.
greatguy57078
greatguy57078
Looks like a rigid kit. I will have to compare but I agree other than the detent the concept looks to be the same. I seen where they also have a installation DVD, although I bet they have something similar on Youtube. If I know how that detent was set up I could replicate that part as I have all sizes of those detents, also known as spring plungers.
We use those where I work to keep things in time, such as a wheel feeding product into an oven. If the wheel pops out of place the machine shuts off. After you clean out the obstruction you spin the timing wheel around until the detent pops back into the hole and away you go. That is one use we have.
