LOWERING my Bronco
cgbexec
Naples, FL
This looks like a great project. I thought about lowering mine before I decided to raise it. The whole idea is to build something to your personal taste. I like the look of a mini monster truck and I also like the slammed look. Hmmmmmm. I have to think about this a while.
Chris B.
muladesigns1
Goodyear AZ
Yea, but its a 4x4!
Seriously though if you want to lower it with the stock front axle why not mount the springs under the axle like a jeep wrangler set up. That'll drop the it aprox. 4-5 inches.
behemoth
For those that have done this what are the specifics of the front suspension and cross member are you using. Drop spindles or stock mustang II?
I have a project that I am considering this for and I am trying to figure out what is needed at this time.
Bill
chromeyellow
Lecompte, Louisiana
I went nuts and integrated the front suspension off a totaled 06 tahoe on mine.The part that I am not happy about is I converted the rear to 6 bolt pattern to match the front. I think the rack and pinion is going to be nice. There aren't many Mustang 2's around here for parts.
behemoth
I am still thinking about doing this to one, just really curious about the front suspesion. Width, drop spindles and so on. The rears all appear to have gone with the 5 on 4.5 mustang pattern. How did you change the bolt patterns, redrill the current axles or is there another swap.
greatguy57078
greatguy57078
I bought a custom Mustang II crossmember from J.P.L. I went with the stock spindles, and the 11" disc brakes. I also went with the tubular A-arms. I am going to be using all new parts. They have a complete Mustang II kit which is approximately $1750, if you can afford to buy it all at one time. I hope to get started late this fall yet. I will be sure to post plenty of pics when I get going...I need a shop!
Dave
How about a independent suspension rear end assembly out of a 89-97 Cougar to go with it? I'll bet it would really stick in the corners. I know that they used be the hot set up for the dirt track guys around here.
77bronco_ed
Marty,
After some investigation... It is possible to shorten the rear, (in the 40" range) move the wheel wells back even with the frame (approx 5"-mini tub)and add the 4-link. With this set up it is possible to fit 29x18.5 Micky Thomson sportman pro's between the uncut fenders and the frame with 1" clearance on both sides.
This is what I am looking at for the 74 I sent pictures of... If I begin I will post the results.
-Ed
ricky
beaumon,texas 77706
i am wanting to do this with a shell i have.,.any pic's would be helpfull
Greatguy..did you start on your project yet? how close are the frame rails to the mustang 2 crossmember? are the widths nearly the same?thanks
behemoth
In looking at doing this to one that I have, I have hit a snag, the total cost invovled front end complete disk to disk with a power rack is 1800. that is a big dollar commitment to it. There are a few measurements that you need aparently before ordering the crossmember. One of them appears to be the outside frame width. This measurement requires you to remove the front coil buckets first. Lots to think about. Then there is the whole ride height issue to figure out as well, I do not want a ground scraper but something useable.
So mine for now may be a stocker a $40 set of bushings is a whole lot easier to do but I have done that before.
This is goingto take a little more thought.
greatguy57078
greatguy57078
If you order the crossmember from J.P.L. like I did (and my friend), you can have them reference my order to get the dimensions I gave them. I got a few parts (tubular A-arms, 11" disc brake kit) off eBay also, from a parts warehouse located over in Iowa. Feel free to PM me or email me for details. I am getting ready to start on mine this winter, along with my daily driver project. I will be busy!
greatguy57078
greatguy57078
I am meeting with the body shop guy Monday to look at chopping and raking my halfcab/windshield. I will not be using the perfect frame and windshield on my '68 that is on my avatar and in my gallery. I did find a very decent one that needs minor repair on the front edge. I hope to get started soon. I have a ton of new parts to get me started (Mustang II IFS!), as well as a really almost new looking Mustang bench seat I found. The original owner took it out of his '68 Mustang to install regular bucket seats. I was very lucky to come across it and one of our fellow Bronco Brothers took the time to pick it up for me pack it nicely, and send it all the way to South Dakota. Thanks Gummi Bear! More to come....soon.
behemoth
no progress on mine, I am still working on the floors and windshield frame. I will need to get bronco as it is cleaned up before the front end decision is made.
Gummi Bear
It's good to see that the seat made it up there in good shape. I packed the snot out of it.;D
I've been watching on occasion, and hoping for an update. Keep us updated!
greatguy57078
greatguy57078
;D I am sending seat on to have it recovered and slightly modified. I hate to do it, cause it's such a great looking seat, but I think it will be awesome with the 2005 headrests installed and some modern side supports. I have so many parts, and so little time. I will be sure to keep everyone posted. Thanks again Gummi Bear for getting the seat to me. You are truly a Bronco Brother!
77bronco_ed
I purchased the shortened rear end for mine... But... I just went on a trip to Australia which burned up a bit of money so things are on hold for a bit ;(
-ED
