LOWERING my Bronco
bronko69er
EB Addict
Renton, WA
Well I put it on the scales today to figure out the front spring rate. The truck is a fat little piggy. It weighs in at 2920lbs 1300 in the rear and 1600 roughly up front. There was junk in the bed so it is actually a little lighter in the rear than what these weights are, but no gas so it will hopefully come close.
So explorer 5.0, aod, explorer rear and all stock bronco steel parts. No hardtop.
This is exciting! Under 3k! Cant wait to get mine done! Still collecting parts.
behemoth
If you are using the standard coils the 375 spring rate is what I was told works. At this weight. With coil overs the 600lb spring rate is what was recomended to me by heidts and qa1. I am running qa1 coil overs in the front.
Next step is to see what will remain of the inner fenders and supports after a few full compression checks. I doubt much of the front edge.
I moved the front axle forward just enough to cause my heartache.
behemoth
Inner fenders
Well, I took the stock mustang II shocks installed it with no coils and bottomed it out for full compression.
I measured the tire and it is roughly 26" I added one inch for the bump stop built into the shock and one more just to add a little more clearance.
So 14" is from wheel center, I measured and marked up some cardboard and used the spindle, marking the inner fenders.
So there you have it basically the inner fenders need to come up on the top and front edge 1 3/4" or just 2" for ease.
I do not know what this will do for the battery tray at the moment. It looks as though there will be considerably more room at the rear for the battery.
behemoth
Pulled the inner fenders today, so glad I sanded and painted them all nice and pretty.
I used the template on the passenger side and transferred it to the drivers, crap the measurements are different.
Here are pics of the adjusted passenger side inner fender support. The pics are taken at full compression.
I also put the 1/2 spacers on to check arm clearance on full lock turns. Well, 1/2 " does not clear the arms and 1" will clear the arms but not clear the fenders when turning.
The good news is that the 600lb spring rate springs did the trick with the coil overs.
3 1/2 " of suspension travel with the mustang II that's it.
I would like to see what Dale has done with the front inner fenders or if it is just my problem since I moved the front forward a bit.
behemoth
The one I blame for this illness.
greatguy57078
greatguy57078
I will contact Dale (again) and see if he can send some measurements along with a few pics. Stay tuned...
greatguy57078
greatguy57078
Still no answer from Dale. I did email him at another email address that I had for him. I will post when I have an answer.
behemoth
76 front clip under there so he cheated some what. I spoke to him and the kid many years ago at a Fab fords and again down in santee/ elcajones.
I have to start over with the inner fenders and make them to fit.
I also picked up a set of upper a arms that will clear these rims with this backspacing.
Nothing no pics at this time.
No problem lets see what Dale comes up with.
greatguy57078
greatguy57078
I just got an email back from him and he said that he made no changes to his inner fenders. This is what he sent me:
I'm sorry I didn't get back to you sooner, but things have been off the hook
here at work. I didn't have to do anything with my fender wells either
front or rear so I can't help you in that regard. I joined classic broncos
over a year ago so I look in from time to time.
Keep us up to date. I should be where your at on my front end very soon. Thanks for all your input!
76 bronco J
>>>>> anybody know this lowered bronco runnin' down a camaro .....it's from may 1,2008 , the time looks like a 12.2something.. the announcer said it's a 68 & the owner is Jeff Jensen.....[youtube]<object width="660" height="525"><param name="movie" value="http://www.youtube.com/v/h_i-IT125e4&hl=en&fs=1&rel=0&color1=0x006699&color2=0x54abd6&border=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/h_i-IT125e4&hl=en&fs=1&rel=0&color1=0x006699&color2=0x54abd6&border=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="660" height="525"></embed></object>[/youtube]
behemoth
That bronco was in bronco driver. That is all I know about it.
Well, I have the inner fenders trimmed up out of the way of the tire just need to make new ones.
The turquoise one has different inner fenders also, they went higher than I did.
Who knows maybe you will not need to do anything.
Bill
73stallion
Eugene, OR
aw what the hell, here's the rest of the pix i have of it.
LilRedBronco
Belmont, California
yep, here's his inner fenders
If you are a motorhead and that picture doesn't make you nearly weep with joy there is something wrong with you.
I can go to the SF Museum of Modern art with the wife and have her explain culture to me and I can stare at 99.9% of the stuff in there and I have no idea WTF I am looking at or why.
I look at that neatly designed and executed motor and it is like what it must have been like to look at something Rembrandt or Salvadore Dali has done for the first time.
behemoth
Basically just a bump, not a whole lot going on I have mine at ride height and there was no way the inner fenders and support were going to work.
So I am still working on the inner fenders and re creating them.
I do not think that there will be enough room to put the mass air sensor on the inner fender anymore. So another problem has arrived.
greatguy57078
greatguy57078
Not much going on here either. With the cold weather that has hit us now, I will be purchasing a propane heater in order to make any progress before spring hits. I will remain optimistic that this baby will be running by summer! :cool:
77bronco_ed
I realize you guys are well into your builds and are doing a fantastic job... I am curious when you began investigating the front suspension did you look into the crown vic front suspension at all? I seen on some of the ford truck forums that many are using this on the older pick ups as a swap...
Thanks,
greatguy57078
greatguy57078
I did not look into that myself. I went with the Heidt's Mustang II because it was a clean and somewhat easy install. I wouldn't say it was the cheapest, but using a 4.6 DOHC engine isn't a cheap or easy thing to do either. As always...stay tuned! And MERRY CHRISTMAS!
behemoth
I looked at my explorer in the driveway for front ends but went with the mustang II suspension. It was the quickest way to go I thought at the time.
Any progress out there? I am still looking at the inner fenders my friends have suggested trailer fenders as an option. I guess the lowered truck scene uses them alot. Not much going on really just looking at it and dreaming.
