LOWERING my Bronco
greatguy57078
greatguy57078
Well, late to the thread but way early on the idea. About 20 years ago I did the "C" frame in the rear method with a Granada 8 inch rearend and used an 88 Ranger 2wd twin I beam front end under my '72. At the same time i stuck an 85 3.8 V6 T-Bird engine and AOD out of an 88 Mustang in, then turboed and Holley ProJectioned it. Kinda my answer to the GMC Typhoon or Syclone or whatever it was they were doing in the late '80's. Did a few body mods like the old reverse the front fenders for rear flares; front and rear bumper delete and rollpans instead. Dropped the rear plate to the center of the pan with a hidden hitch behind it. Used late '80's C-30 dually rear fender clearance lights for side markers. Stuff like that. I'd upload a couple pics but I just found this forum when researching vent window deletes. Anybody got any info/ideas on that?
Thanks,
Jim
I am posting the pics that Jim (CosmicArkie) sent me. Looks like a nice ride to me!:cool:
greatguy57078
greatguy57078
Ok ... so some progress. I am trying to sort out what to work on first as the winter months get nearer. I did finally get the top back. Like I said, my body guy is good but slow at times. He takes on too much so the halfcab has been there since...April of '09?%) Got it paid for and set it on top of the tub tonight (see pics).
Next the doors and fenders come off, and I get to work cleaning up the front and hopefully get some bodywork done on this beast sometime soon depending on what we decide to work on first. Still have to decide if I want to lower the floor to make more room. I am only 5'6 so height inside the halfcab is not a problem for me, but even for me it is very tight inside. Kind of like a go cart with a chopped roof. :eek:
We hope to get the underside done and the tub in primer sometime soon, but with other projects (too many vehicles to maintain), I can't really set a timeline. As always I will upgrade with opics as we move along through the winter months.
I did decide to go with the coilovers like Bill (behemoth) did, as I am tired of trying to squish too long and too stiff of a spring into the Mustang II crossmember, only to find out later they are too tall or too stiff and too soft. Soon I should be able to post pics of the truck setting on the frame so we have a better idea of what the rake is going to look like with the heavier 4.6 DOHC engine. I did find a great street rod friend (Justin)to walk through this process with. He is fresh out of school, but eager to help out and keep me thinking ahead to keep me moving forward. I am pretty excited about getting this moving again, so hopefully I will burn some rubber next summer. :cool:
greatguy57078
greatguy57078
Sorry about the pic quality, but my lense must have been dirty tonight. I will snap a few more tomorrow, and be sure to include inside pics that show the cuts made from the inside for all you guys curious to know how they made it all fit.
chrlsful
Research,research, research
(sorry, I stopped @ page 1 of this thread)
2X contactin the #19 issue BD mag feature guy. He's gunna B just 1 other source but may B a goodun. Call John (editor or sompijn) or email him over there (TN) to get the fella's name/contact. He was very personable with me for an issue #2 question I had.
greatguy57078
greatguy57078
I did decide to go with the coilovers like Bill (behemoth) did, as I am tired of trying to squish too long and too stiff of a spring into the Mustang II crossmember, only to find out later they are too tall or too stiff and too soft. :cool:[/QUOTE]
OK I pulled the trigger. Last night I was just sitting and thinking about how to go about getting all the parts for the coilver change, and I came across a new set on eBay, so saved some $$$ there. I also went ahead and ordered the coils today from Speedway.
I will take the lower A arms to work tomorrow (yeah I work 6 days a week ?:?) and see what I can do to modify them to have a tube to mount the bottom of the shock to. These are the only lower arms I have seen that for some reason have no tube to slide a mountiong bolt through.
I will use the plasma cutter to cut out the cup where the OEM coil would have been located. Hopefully by next week I will have the front end assembled and the wheels mounted. The wife will be overjoyed to actually see any space at all open in our garage. Soon she will have to scrape the windows in the morning, and she will lose all the patience she has had with me since spring.:mad:
greatguy57078
greatguy57078
I have posted a pic of Bill's lower arm to show a comparison to what mine look like. These are not the Heidt's arms that Bill got in his kit, but something I picked up locally from a place over in Iowa. They seem plenty rigid and beefy, but for some reason have no mounts for the lower shock. They have two holes with a threaded nut welded to the top of each hole inside the coil cups (pic 1).
I will trim the cups out with the plasma cutter similiar to what Bill did. I will set it up in the mill and cut a hole for a 3/4" piece of round stock to pass through so it looks like the third pick (without the section in the middle cut out yet).
Next I will take a piece of 3/4" round and tap one end for the shock bolt, then use an endmill to cut a radiused notch on the threaded end to allow it to fit tighter against the inside of the arm after I pass it through the hole I cut into it. After TIG welding the tube in I will trim out the center section to fit the new shock. Sounds pretty easy huh? %)
greatguy57078
greatguy57078
I hope you'll forgive me for saying this but, Your sick, sorry.%):eek::eek:;D;D;D
If you don't like this project, maybe my next project would interest you. Here's a hint...
behemoth
on your arms there are two bolt holes on the bottom, that is where the original style shocks would mount. So those holes are the center of the lower shock eye. I will take some measurements on mine in the am if needed.
77bronco_ed
Picked up a few more parts...(could not get my self to cut my green 74) Wife is going crazy, "So now you have 3 Broncos" :eek:
I won't mind cutting this one up... I purchased the tub and doors.
Also traded a gear box for a pretty nice half cab top. I am starting to stock up on cutting wheels.
Getting ready to move at full speed, have a lot of parts ready to go...
You can see it is going to be a bit easier to justify cutting up the floor versus the 74
I may go with a bit more radical chop (after all this will be a street rod)
I'll experiment in photoshop to see how much I can go with out over doing it.
Who knew that I would be using the photoshop bronco that I did for Marty myself?
I may coble up the front floor pans. No harm here right... look at em ;)
After the tub arrives I'll ponder changing the front floor pans to be similar to the passenger side (4-5 inches lower) and move the step back slightly for both sides. This will provide about 5" more head room for the chop.
If Jami is kind enough to give me a portion of the hard top I may experiment with the full cab chop option. I believe I will need to extend the top a few inches overall if the chop is radical. Otherwise windshield rake problems may occur.
I hope welding is like riding a bike.
-Ed
behemoth
I would raise the rear bed floor about 6 inched to keep it flat with a good C notch underneath it.
lowering the front floor is a good idea but with an after market bench seat you can get it down low with stock floors.
At the height I set my front at the inner fenders had to be rebuilt, then this leads into battery issues, mass air sensor issue and so on.
Looks good and I agree I also would have had less concern in cutting those floors than on what I had also.
77bronco_ed
Good idea on raising the rear floor pan level... I want to modify but would like to retain the appearance of stock if possible .
Might be odd looking at the tail gate area? Have to think about that...
The more I look at this half cab, I may want to clean it up paint and put it on the 74.
It is in pretty good shape, a good find ;)
behemoth
I doubt you would see it I would just extend it all the way back to the tail gate. the only time you would see it is when it is down.
greatguy57078
greatguy57078
Well I am finally back online. The roofers knocked out my internet for the last few days. I have stayed late at work and made alot of progress on my A arms. I hope to have them welded up tomorrow or Monday at the latest. If I can get them done after work tomorrow then I should have the front end together this weekend yet. I took a few pics to show what I had to do to get the mounting tubes installed, as my A arms came without these tubes. Keep chipping away guys!:cool:
greatguy57078
greatguy57078
Wow! Talk about CLEAN green! I wouldn't want to cut into that either!:cool:
77bronco_ed
I know... I had bought this for just for doing up a street rod... After getting it I have been hemming and hawing it was nicer than I had expected.
It needs a little work but has so much potential. I thought it would make more sense to sell my fiberglass bronco but I like it too much as well?
My family thinks I am nuts.
