LOWERING my Bronco
greatguy57078
greatguy57078
I work from 5AM until 3:30PM Monday-Friday and have HS soccer practice 4PM til 6PM every night after work. Then we have games every Friday and Saturday. That leaves me with one day to get anything done, including the mowing, maintaining everyone's vehicle, and trying to get some sort of rest. I hope to have time to get some things done here very soon.
I still have not got the body off, but it has to be something as easy as just prying it loose. This truck is very clean and only 70,000 actual miles on it. It was also a service station truck that was kept inside it's whole life, so it is by no means a rust bucket. I have to get the body off and set on the lowered frame in the next couple weeks, so the wife can have her spot back in the garage before it gets colder outside.
greatguy57078
greatguy57078
I have decided to move the axle back 3" to a 95" wheelbase. Yeah this will be taking a step back, but I really think it's a step in the right direction. I really like the look of the wheel more centered in the wheelwell.
I have the trans back on the frame, and my brother is coming over this afternoon to help me pry the stubborn body off the old frame. I found a local guy that is willing to help me get the EFI figured out in the coming months, so I hope to have some smoke rolling off the tires this winter/spring!
I am getting old Red ready for winter also, so I have two projects (well 3 actually!) going on at the same time. I would start another thread on my red halfcab, but that would be just ONE MORE thing that I have to do! %)
I got backed into by a rental truck one. I was driving a friends triple black 4-speed GTO convertible. The bad part, he was driving the rental truck. He back into his own car. I couldn't get out of the way fast enough becasue his roomate (another friend was behind me) and more realistic I couldn't find reverse fast enough.
Keeping tabs on this. Looking forward to building another Bronco (no lift this time). I like this one, good insperation. I have a few other odd ideas that I want to try as well.
behemoth
Preliminary settlement estimate came in at 9k.
Marty, sounds good on the axle move, that will make a tight fit for the tank.
I am thinking of cutting the bed to get the ride level, not a scraper just more level than it is now. I can run it low, just don't like the bump stops hitting on the bigger bumps.
greatguy57078
greatguy57078
I know yours is at 94". If I move mine to 95" will I still clear the rear crossmember? Or would 94.5" be far enough? You mentioned something about a differential cover you're using that barely cleared the crossmember? :-X
behemoth
I have a large diff cover and we had to trim the rear cross member a bit in order to clear it.
I think If you were to remove/remake the rear crossmember out of tube and angle it up closer to the floor you would not have an issue at that lenght.
I cant think of the manufacturer of my diff cover, large aluminum black with a flat face. hmm the early onset old timers is hitting again.
greatguy57078
greatguy57078
I was wondering if I cut it at an angle top front to rear bottom if that would be enough to clear the stock cover. I guess I would have to look again at how close the crossmember comes to the gas tank. %)
77bronco_ed
Glad to see you Bronco busy again Marty...
I have been working on my other Broncos a bit. I'll get back to the street rod in a few weeks.
It took more work than I thought to get the rear end set.
behemoth
Basically looking for motivation to build it again...
blazinchuck
I hear ya Behemoth! mine's still on the back burner. Im planning to steal some income-tax money to buy my front suspension. dont give up yet...look at it this way- You've done the hardest work already. you've figured out all the "un-knowns" by this point. all that's left, is replacing the bad. so...get out there, and get busy!;);D
croft75
I'll give you $500.00 Canadian for it to get it out of your garage.
If that lowball offer doesn't piss you off enough to get going again call me:)
seriously i hit a wall at one point in my resto, for me I needed a push to get over the top and then I couldn't work fast enough to get it back on the road. Good luck.
greatguy57078
greatguy57078
Well one more bump in the road. I am laid up for a wile longer as I had a shoulder I tore up at the end of soccer season. I always had a high tolerance for pain, but I lasted months with a nagging pain in my shoulder. It had to get to the point where it would slip in and out of place before I finally had it looked at.
The last week of soccer practice I was crazy enough to get in the goal. When a coach gets in the goal, there is nothing more than a player would like than to score on him. I don't have to tell you how hard they kick to achieve that task! When I blocked the ball it drove my arm up and back to the right. It then bounced down and to the left where I dove down on it, where the second player kicked hard and got more of my right thumb than the ball. I walked it off of course.
I didn't notice any real problem til I had to work with it. As time went on the pain became more intense. Well it turns out the bone spurs in my rotator cuff and collar bone cut through the muscle/tendon so you could see the second layer through the first layer. The second kick bent my thumb way back tearing the tendon where it attaches to the elbow. They say with meds/injections it will recover, although it still feels sprained all this time later. To make a long story short, I had the surgery so I am out of commission for a few weeks. I hope to be back on track and back at work sometime in February.
Hang in there Bill. I did get to watch them roll my frame in and out the other day. My 14 year old daughter drove through the double garage door a cpl weeks ago, so there went some more Bronco money! I hope to get going on this (with a lil help) as soon as possible. Needless to say, my goalie days are over! :p
77bronco_ed
Hope you are healing up Marty, Nice to see you back at it Bill.
Looking at mine again. I am having second thoughts on my approach on the front end. After getting my cross member set when looking at the position of the hats I need to slice up the front frame pretty good to get the hats positioned. Appears that the top of frame would then be in line with where the front bumper height is. I think there is a lot more work in trying to use any of the old frame for my application.
I may buy new frame rails to attach to the back half I created or... Since I don't have two much into the rear frame (mat'l and a cross member) I may just price a standard ladder bar back half and have them jig weld the needed new front rails and a cross member for the ride height, and wheel base I am after...
Basically have a frame made up, and bolt on all the parts I have. I would then only have to add mount points for the engine,trans and body.
I want this to come out nice, I do not plan on building anything else after this..
I already tripled my work by using this totally rusted tub. I want to simplify something somewhere ;)
behemoth
Marty,
Been away for a while, mmm staples very nice, hope it all heals up well.
I have been messing with it some, I will have to remake the front inner fenders again. I never really liked what I did with the first ones anyway. I think the battery will end up in the bed behind the wind screen or possibly still up front only a very small battery instead. It will never have any off road lights or a thumping stereo so I should not need much. That and I live in socal so cold is really not that cold.
I look at it with just the fenders and inner fender aprons on and I think this could work as is but I doubt it would be strong enough. Those stock inner fenders are a big part of the front end strength.
My insurance money is probably going to go to a doctor as well, my smaller pup has a bad knee, that will require surgery to repair.
All in time guys, who knows we may all meet up with them sooner than we think.
chrlsful
"...possibly still up front only a very small battery instead..."
Keepin 'up frnt' is a good idea (in my mind). I can't afford this but an optima or other non-luquid battery can B mounted on it's side. U could then stuff it in the fire wall on the pass side (sorta where the glovie is). Keeps the use of copper down - nother reduction in expense.
behemoth
After aligning the panels as best I can I am at the conclusion that it really is not going to get any better. I have them as close as I can get, a body shop will have to do the rest.
I am now working on rebuilding the custom inner fenders, and while that is a whole lot of fun I took a break and did this to the truck.
Can you figure out what I did ?
sprdv1
REBEL
Ouch Dude... First time I seen that.. Hope you are recovering well!!!
behemoth
Yes I took 6 1/2 inches out of the bumper, 3 1/4 from each side hidden by the bumperettes. I will sand down the welds and get it re chromed at some point here if and when I ever get it painted.
The inner fenders are a little bigger this time to clear the tire more when turning at full compression. I had an issue with that before, and as a result there is little room left for a battery up front. We shall see if not the location in the bed on the passenger side in front of the wheel well is my next choice.
I don't want to do it but I am letting the truck tell me where things are going to go.
Yeah Marty how are you healing up ?
Heus33
That looks really great - I just chopped the ends off of my blue one back in the day. Yours still retains that nice little curve at the ends, very nice.
