LOWERING my Bronco
greatguy57078
greatguy57078
I don't think my body guy took any dimensions down but there is a few reference numbers written in marker on the door frames. I do know we went with a 3" chop.
77bronco_ed
in addition to giving up on the aftermarket Sheetmetal I bought. It just isn't worth the fight. Externally the fit can look fine, but the supports and everything else needs adjustment.
QUOTE]
I will need to buy sheet metal for the front end when I get closer... Are you saying that you purchased after market, rather than OEM style from the vendors?
behemoth
Nope I purchased the latest best fitting fenders from a vendor. These are the new just as thick as stock no holes fenders. The core support is also this newly released dynacorn part. The grill is the stamped from original for tooling dc grill. It's all not bad, just trying to put all of these different parts together really sucks. Especially when it is shipped to you.
I don't think I'm chopping my windshield as much as I am tilting it back a little bit
I've ordered hagan hidden hinges for doors bigger than 3 1/2 inches. I'm not suiciding them anymore. I don't need work twice as hard with no access to the rear without more cutting.
greatguy57078
greatguy57078
Here are a couple pics of the hidden hinge kit installation. I did not do this (yet), but this is the same kit that I bought and what it looks like installed. This is Dale's work, so if you have questions please PM me and I can give you his contact info.
greatguy57078
greatguy57078
In regards to the rake of the windshield. Here are a few pics and hopefully they will be self explanitory. They cut the hinge mounting point and removed material to allow the windshield to fold back farther towards the back.
greatguy57078
greatguy57078
Here are a few more pics. The last two show the finished product. I can take a few more if you like, or need more questions answered. I for one need a visual aid sometimes, or at least it helps. %)
greatguy57078
greatguy57078
You can see the rake of the windshield in the second pic. In the third pic is hows how much lower it looks from the front. I think I will remove the triagular pieces in the lower front of the window frames and just run a mirror on the door skin instead.
behemoth
Thanks for the pics I'm still waiting for my new hidden hinges to arrive. I ordered Hagan's and they are apparently back ordered. I also picked up an original core support to use as a template for fitting this messed up new part. Slow going, still looking for stock fenders now though.
greatguy57078
greatguy57078
OK. I am taking "Old Red" (well the chassis) back down to the Bronco Connection this Saturday. Now that that's done (my part anyways!), I can get back on the hot rod Bronco project.
I will be taking the 4 link back off to get it out of the way. I have decided that I am going to cut the rear frame notch bigger and move the rear axle back 2.5-3". I just like the look much better. At least I will be back on the project and moving in a positive direction.
Here is the notch kit that I am going to use. I will probably cut it down some as it's huge and I don't think I need that much. Of course I will have to "undo" what has already been done, but I have always been better at tearing things apart anyways. :-X
behemoth
Yeah I hear you there, in all my efforts to keep this near perfect bed its going to have to go. I am just going to use 2x3 rectangle tube for my notch this time and be done with it.
greatguy57078
greatguy57078
Yeah I am thinking that same thing. I would like to keep the bed intact but I think in the end I would rather have some clearance under there.
I had a friend that had an old '34 coupe he hotrodded out, and it looked great but would bottom out at times on the interstate. He ended up tearing it all down to get it right. I would hate to sacrafice looks for perfomance myself.
behemoth
I notched mine as high as I could go to the body, and in order to drive it I have to air up the bags to keep it off the bumpstops on bumps. I hate it, it rides so nice and smooth, but the rear is just too high now for me. So after I re assemble the front end again, do the hidden hinges I will notch the rear more, cutting the bed. I am thinking of just raising the whole thing up to avoid the cut look.
greatguy57078
greatguy57078
I was wondering if I could move the notch up and add a 1" body lift. Or...would that defete the purpose?
greatguy57078
greatguy57078
So.... Are you saying that the ideal WB for the tires to look centered in the wheelwells is around 96"? Taking notes for when I start my build.
I thought I had posted a couple reference pics awhile back in this thread. I will go back and look again.
bronko69er
EB Addict
Renton, WA
I did ask before and if I remember right is was +~1.5" so 93.5-94"....
I guess what I'm asking is what made you change your mind? Does it still not look right? Do you think 96" will look better?
greatguy57078
greatguy57078
When setting my frame up I went with what I thought was the right thing to do, and stuck with the stock 92" wheelbase. The Bronco on the left has a 94" wheelbase. The Bronco on the right has the stock 92" wheelbase.
It would be up to the builder but I prefer the look of the longer wheelbase which is more centered in the wheel well. It will be more work and a step backward, but now is the time to do it.
I ordered new bars for the 4 link (anyone want the old ones? You can still use them and just weld your mounts closer than I originally did.) and have a notch kit that I thought at the time was a bit too much. This larger kit will give me room to remove material and make the larger notch fit my needs. I will be right around 94.5" to 95" I figure, which will put me just a little further back in the wheel well than the brown truck.
behemoth
I had to trim the rear crossmember a little for clearance for the maghytec diff cover. The front actually was moved a little forward.
