Lowering suspension question
74NJBronco
Livingston, NJ
I lowered my front end from a 5" lift to a 3.5" lift. I read everyone's advise on how to this and what parts to buy. Worked out great expect for the old top spring retainer brackets were bent into a C shape (purchased new ones)LOL.
My question is, about the lowering the track bar or raising it. PO installed a drop down bracket on the driver's side frame rail which was done correctly. The track bar was installed in the lower position of the bracket, 5" lift position. There is an upper hole above the lower one. It measures 1.5" above the lower one on a 45 degree angle. I am thinking this would be the correct position for the 3.5" lift. The only thing that worries me is that the upper position is on a 45 degree angle and not directly above. What do you guys think? Would the upper hole be correct on the 45 degree angle work. Thanks
fordtrucksrule
well the track bar needs to be parrell with the drag link so what ever position it is parell then there you go!
kaw550
I think you would need to try it. Is the bracket wide enought fo Trac bar and bushings to move to the other hole? I have one on a shelf that has two holes. It's not wide enough for the bracket to move to the up.
If it is, you need to see if the front end is centered after the install.
