Found one and will be going to look at it today. My understanding is it does fit the SBF engines if you drill out the bell housing bolt holes.
Anything else I should grab off the truck/F150? Guessing the T-case does not work in the Bronco.
Shifter, throwout bearing, clutch slave cylinder and push rod anything else?
Tim
Tim
