John_parkeriv
After installing my M5OD trans a while back, I've been fiddling around with the rest of my rig getting ready to run it around my property for the first time with the new drivetrain. Engine fires right up, no weird squeaks, nothing. Go to throw it in reverse, just grinding. Tried 1st, same thing. I had a friend press in the clutch pedal while I was under the truck and I can see the throw out bearing pressing into the pressure plate, the clutch just doesn't seem to be engaging.
Most of the parts for my transmission are from the '96 F150 the trans came from: clutch plate, clutch, TOB, master cylinder. The only part that isn't was the flywheel that came with my engine from an '87 F150.
I've heard these TOB's are hard to bleed, but I've bled it about 4 times and the pedal seems solid. Any idea's as to why it's not engaging?
