Ok, cool. So I guess as long as the starter matches the block plate (and not for an auto trans), there shouldn't be any issue with flywheel engagement. And I was already leaning towards a 11 inch clutch, but RA lists a 10 and 11 for the '96 F150. I bought a M5OD-R2 out of a 2003 4wd 4.2 F150 over the weekend from the junkyard. $220 out the door. Appears to be really low miles so I thought I got a screaming deal, til I got home with it and the input shaft wouldn't make a full turn in neutral. Popped the top cover off and the input shaft and counter shaft have some broken teeth, and well as a broken tooth on the 3rd output shaft gear. The rest of the insides look good (almost new, really) but I haven't fully disassembled it yet. The sliders even still have most of the manufacturing marks on them. I moved to the front cover and found that the input bearing is bad. The top cover and front cover had both been off, made noticeable by copious amounts of grey RTV squeezed out from them. When I pulled the front cover off I think I found why the bearing failed. The hole that the oil trough fits in to allow lube to the front of the bearings was plugged with RTV. I'm hoping the parts I already listed are all that is bad. Those, and a bearing kit, plus the $220 I gave for the trans brings me to right at $650 for a virtually brand new transmission. More work than I had hoped for but that's how you learn. Still a good deal in my opinion.
