M5R2 and NP205 Help!!
WorkerBee
Northern CA
I ran into another snag bolting my m5r2 tranny to the NP205. I already ground the tail housing for the shift rail so that is not a factor.
The part that I am going to call the seal retainer on the input of the transfer case will not go all the way into the transmission. It bottoms out because the bore of the tranny is not machined deep enough to allow the whole thing to go in.
even the bolts hit just slightly. I can clearance those but has anyone ever ran into this? I thought Zf's and M5R2's were machined exactly the same?
Also, are all ford NP205's created equal? Perhaps that die cast ring changed along the way and now it's too deep to fit into an earlier model tranny? I know many have done this swap so I'd appreciate any help.
I believe I can grind the aluminum part of the transfer case without hurting much. I only need about 3/16". From what I can tell, I had a married NP435 and 205 combo from a 1977 pickup.
I am trying to get this completed today so any quick insight is greatly appreciated!
bax
Old Member
never seen this but my first reaction since you only need 3/16'' is to build an aluminum spacer out of 3/16 stock. Then put it together.
Revelation
Can The part that you are calling the seal retainer be bolted on the other way? Looks like it may be backwards.
WorkerBee
WorkerBee
Northern CA
Yes it's really odd. Of all the posts I've read about this change I thought it was going to be a slam dunk once I made clearance for the shift rail.
the only other thing I can think of is maybe different NP205's have a shorter seal retainer?
Leave it to me to be the first one in history to have this problem. At first glance I don't think it would hurt it to grind just what I need off the transfer case side but I don't know for sure.
WorkerBee
WorkerBee
Northern CA
I don't think so. it certainly has a slight taper to it. Maybe 1 or 2 degrees. a spacer would probably work but shouldn't it have the full length of engagement into the tail housing for strength? if I made a spacer, it would only engage about 1/8".
broncnaz
Its on correctly. I believe the later model NP205s had a slightly shorter reatainer. But dont know for a fact. I have heard of having this issue with m5od swaps before. its not that popular of a swap so there is not a lot of info out there. but it is becoming more popular. I'd clearance the tranny for the bolts and just use a spacer as was suggested. Probably wouldnt worry to much about strenght issues as its mainly a locating issue to keep things centered. Got to figure the current depth was considered good enough from the factory so its probably not much of a for strenght issue.
WorkerBee
WorkerBee
Northern CA
Thanks for the info. I found a billet "input bearing retainer" on ebay that may work, otherwise I might go junkyard scrounging to find a later model 205. Once complete I'll be sure to share my results. Thanks everyone.
Ranchtruck
I'd grind out the inside of the transmission before grinding down the bearing retainer. Use a sharp burr on a die grinder and it should go pretty quick.
My 205 had the same bearing retainer but the ZF I was bolting it to had plenty of depth to slide it into.
Bronco73
Cape Coral, FL
I think Pete on here had his retainer machined down. That was like two years ago. I think the bolt heads may hit as well.
