Man, I hate that the PO of my Bronco......
chuckji
SE Michigan
Removed the original ‘69 side reflectors and put these generic side marker lights.
Zeke
My PO removed the original paint (well, one coat over the original) that had great patina and put "Plasti-Coat" on it.
gmduncan
Annapolis
Ha...A previous EB I bought, without title, but with DMV paperwork, later came back as a salvage title and frame was out of wack...hence the reason why it didn't have doors and a top because they wouldn't have lined up.
Damn, that sux!
904Bronco
San Martin, CA
Nice work fixing it. :)
Thanks.
I had help with the welding, didn't trust my own. Welder actually made suggestions on how to incorporate the patch piece from another frame.
Used a plasma cutter for the 1st time to get rid of most of the added metal.
Was able to save the wheel well by cutting out the hammer-modified side.
Probably my biggest repair, after doing a drivers door A-post.
trailerjack
trailerjack
Central Texas
Yeah, sounds like we've all run into some interesting "mods" that were either done in thrift or due to necessity. Makes it all the more interesting.
Mikesimp70
Mine had a 3/8 plate welded to the bottom of the frame in front with a ball on it for putting boats in and out of Lake McConaughy. Couple hours with a smoke wrench to remove that one and grind it out.
56f100bbw
Tucson / lakeside AZ
On my 71 1/2 cab bronco the PO took brazing rod and made the roof and the tub one piece then he took bondo and sculptured it in it was fun separating the roof from the body
Bajabrewer
Someone in the history of my 66 brazed riveted & bondo/fiberglassed the front quarters to the eyebrow grill. The rears were worse & cut with a hacksaw & no guide lines.
Madgyver
Bronco Madman
why hate?
it's your bronco now.. Do as you please to it. Build it how you want it. Your Bronco will love this new chapter in its life...
