Manual shift collar replacement
ryan97
Richmond
Ok, need some help here guys. My manual shift collar has been broken for years. PO had it held together with hose clamp. I have had the replacement part laying in the garage for a couple of years and thought I'd finally replace it today however I cannot get the new one seated all the way. Seems like it needs to go down about another 1/4" to fit into the slot at the top of the column.
I am not seeing any movement in the engine compartment. How do you make the steering tube engage the shift levers? The tube came "out" about 1 foot when pulling the collar.
ryan97
ryan97
Richmond
Pic 1
Picture 1
ryan97
ryan97
Richmond
In picture 2 you can see where it has been "nicking" the collar wanting to go into the slot.
ryan97
ryan97
Richmond
I am getting movement on the back lever, but not the front (R&1 or 2&3?). Looks like if whole collar would go 1/4" more down column, would be there....
ryan97
ryan97
Richmond
Starting to think the new collar is the problem...
Can put the old one on (with out signal harness and fits fine). New one super tight fit and doesn't seem to want to go all the way down.
Hey Ryan, just got some measurements to compare to on a new collar like yours. I wonder if it's got some extra material that's not letting it settle down into the shift tube?
I notice that yours has what appears (in second pic) to be some extra material like a reinforcing rib(?) beneath the square "bridge" section between the inner sleeve and outer bell. On my new one that little bit of extra material is at the outer bell instead, and the inner tube section is perfectly round with only a slightly wider section at a shelf 2/3 of the way down. I'll try to get a pic.
Maybe you can see any differences with this pic? Let me know if you find anything on yours and need a pic from another angle.
phldwsnoc1
Jarrettsville, MD
Sorry for this experience. Sounds very similar to my own. If you insert the lever into the old collar and check the fore-aft movement, then do the same with the new collar, I think you'll find the clearance issue that is preventing you from engaging 1-R. I had to remove quite a bit of material to allow the lever to pivot a sufficient amount rearward on the handle end. Make sure your underwood levers are aligned to the shift tube on installation as well.
Bloody shame this is what we come to expect with new parts.
ryan97
ryan97
Richmond
Made progress on this last night and hope to reassemble tonight and test all shift function once steering nut has the column back in compression.
Although the replacement part was "almost" identical in dimensions it was 1-2mm bigger in many of them which would not allow the OD of the inner collar to seat in the column bushing. Additionally the ID of the inner collar would not fit over the steering tube. I had to grind of a significant amount of material burning up 5-6 different dremel bits to get both to OEM tolerance. This part was WH #2598 but I have had laying around in the garage for a few years. I am told they possibly have a new supplier or casting for this so hopefully not an issue now?
ryan97
ryan97
Richmond
Closing this out - got it back together after grinding off a significant amount of material.
Ahifts much better and "tighter" now. Cleaned everything off and applied new grease on re-assembly.
Also re-learned and old lesson, just paint everything primer black..... Much easier to touch up scratches!!!
