Mass Air Sensor Question
Nightstick
Bronco guy
I've slowly gathering the parts to complete an EFI swap on the 351w I built forever ago. I have a 75mm TFS TB and I'm gonna run 24lb injectors. Found a "deal" on a BBK 8004 76mm MAF sensor, and just wanna make sure that it will work well with the system. I've read opinions on TB/MAF sizes and everyone seems to have different things to say and run different setups. I'm looking for a happy medium I suppose. Thoughts?
Viperwolf1
electron whisperer
Big throttle bodies can be real touchy when just cracking the throttle. That first 1/4" of throttle lets a lot more air in than a normal sized TB would.
MAF size is not too critical. I would be leary of used aftermarket MAFs because you have no way of telling if the output is correct for the ECM you're using.
Expect a few problems and plan on having it tuned.
Work, probably
Well, questionable
When you are changing that many parts, engine size, MAF, injectors, cam (I am sure the airflow through the motor will be different even if you did use a mustang roller cam), intake will flow much different then what was originally programmed into the computer.
With that many changes, get it tuned. It will be the only way it will run right.
Nightstick
Nightstick
Bronco guy
I guess I should have mentioned that my plan was to get it tuned, or buy the tuner and do it myself. The one I'm looking at is "used" but has never actually been used. Installed, but never run.
Pat... Uh negative, I've never made mention of wanting to save gas or started the "how can I get more MPGs" thread. I'm well aware that I'll be around 8-10mpg with the setup I have. It won't see many trips over 20 miles anyway as it's going in a mostly trail rig.
Thanks for the responses. This is the motor that y'all helped me build last year, I hope to have all the parts gathered and ready to drop by late fall/early winter. Other projects have sidetracked me from getting it running, but it has sat dormant long enough!
Tuned, it should work fine. It will give you a fair starting point.
The throttle body may work as well. I would try them. I had a 70mm on a stroked 5.0 and was having issues with tip in drivabilty. I could not control the power off idle. Power was an on/off switch. Either it would idle or it was accelerating (pretty good too). If the 75mm throttle body works for you, great. But if you find it a bit surgy just off idle, look into downsizing it.
Nightstick
Nightstick
Bronco guy
Thanks for the tips fellas, I'll keep them in mind. Got the MAF for $190 shipped, so I saved about $40-50 I guess, not bad.
