- Nov 28, 2001
- 10,550
Interesting, I may not have an Astro HB then. I measured the bore, and it looks to be around 1.75-1.8”. This an SD hydroboost?
That's absolutely huge! I'm not sure what that is!
Todd Z.
The Astrovan bore is 1 5/8". The SD I have is 1.75.
It's a 94-95 h-boost, the push rod has a 5/8" hole , the 90-93 have a 1/2 hole. I don't have a 90-93 unit to see what the bore is.What year Astro van has a 1 5/8" bore? All the ones I've seen between 93-05ish are 1.25" bore.
Thanks,
Todd Z.
If I remember correctly, the 2 bolts/holes that attach the SuperDuty M/C to the booster won't line up - I think the superduty has a wider bolt pattern. Pretty sure the "flange" where the MC inserts into the h-boost is bigger than normal too. I'm not familiar with the Mustang H-boost - what MC are you using? Astro?Sorry to bring this back from the dead, but I was wondering if anyone knows if the 1.5" m/c will fit on the Mustang H-boost?
I'm mostly worried about the diameter of where the m/c fits into the h-booster. I can make an adapter plate to bolt the m/c to the h-boost if the m/c will fit into the h-booster. None of my parts stores/salvage yards has the F-350 m/c in stock for me to look at.
I need to make a big upgrade to my master cylinder for my new axles. I'll be running 96 F350 front brakes and JB6 rear brakes. I'd like to keep my Mustang booster if possible.
I'm using the Mustang MC. The Mustang H-boost and MC have the mounting bolt pattern at 11 & 5 oclock instead of 3 & 9 oclock. It can be turned (if it will fit- I'm not sure), or I can build an adapter plate between the HB and MC. An adapter would allow me to bolt the F350 MC on IF the flange fits inside the HB body. Or I could possibly build an adapter long enough to fit the MC flange. I'll just have to figure out an extended push rod.If I remember correctly, the 2 bolts/holes that attach the SuperDuty M/C to the booster won't line up - I think the superduty has a wider bolt pattern. Pretty sure the "flange" where the MC inserts into the h-boost is bigger than normal too. I'm not familiar with the Mustang H-boost - what MC are you using? Astro?
got it. Well, FWIF, I really like to see people matching the h-boost to the MC and to avoid using any kind of bracket. It's just such an important function. I don't like seeing those angle brackets. I went to great lengths to flip my 5.0 intake so I could run an unfettered H-boost/MC setup. I'd really recommend the SD h-boost and MC combo I did. If the stock SD reservoir doesn't fit, those Astro reservoirs fit the SD MC great. The SD MC/h-boost combo didn't do anything for my issue of not being able to lock up the fronts but I'm glad to have all Ford parts and a matching H-boost/MC setup with no funny business between them.I'm using the Mustang MC. The Mustang H-boost and MC have the mounting bolt pattern at 11 & 5 oclock instead of 3 & 9 oclock. It can be turned (if it will fit- I'm not sure), or I can build an adapter plate between the HB and MC. An adapter would allow me to bolt the F350 MC on IF the flange fits inside the HB body. Or I could possibly build an adapter long enough to fit the MC flange. I'll just have to figure out an extended push rod.
I actually found that our Napa has the F350 MC in stock with no reservoir so I can go look and take some measurements. I'm going to compare with a 99-04 SD MC that has a 1.375 bore. Both put me close to the "stock" MC bore to caliper piston area ratio (19-21:1). The OBS MCs have a 1.25" bore and put me around 23:1.
yeah, totally get that for sure. It really adds up and goes over planned. I haven't seen the mustang h-boost but yeah could need new hoses/adapters, could snowball messsing with the pedal etc. etc.Agreed on all that. I was able to accomplish that with the Mustang set up (no bracket/matched MC).
At this point my goal is to finish up my axle swap with minimal cash output (budget is already blown as usual), and minimal added "projects". So keeping my Mustang HB accomplishes both those. If adding a different MC gets complicated, I'll resort to swapping the SD HB as well. I haven't read up on what the SD HB swap involves. I'm sure the pedal push rod and hoses will change from what I've got now.
Bummer it doesn't fit. Were you heading down this route of sizing up the MC just to get the MC bore to brake piston ratio in the right range? Reason I ask is because when I moved from the 1.25" Astro MC to the 1.5" SD MC, I didn't gain any braking improvement. I know the bigger MC is better on paper but after upgrading, I still question what I actually gained and I'm on one-tons with 41" tires. My 1.25" Astro MC had zero issues locking up the rears when I still had the huge Chevy JB7 calipers. In fact, I sized the rears down to the eldorado calipers and I could still lock up the rears with the 1.25" Astro MC. It's always been the fronts I can't get to lock up on dry pavement and that's why I tried the super duty MC but it didn't make any difference. I barely felt a different in the pedal firmness with the bigger MC bore.It looks like none of the MCs I'm looking at will fit into the Mustang HB. The bolt spacing is the same, but the flange that fits into the HB won't fit.
The Mustang HB/MC flange is 1-1/2".
The 96/97 flange is 1-5/8".
The 99-04 SD flange is 1-3/4".
I'm betting the 05+ SD flange is the same 1-3/4", I'll be able to measure one later today.
I have an Explorer EFI upper in the "stock" position and no body lift. You said you flipped the upper intake to clear the HB. Did you try to turn the HB 180*? Did it not fit? I could see it interfere with the steering column possibly.
I'm also thinking it could be possible to put the SD HB on the Mustang mounting flange, it has a slight angle to it pointing it away from the EFI manifold.
I found a salvage yard close with 99-05 and 05+ SD HBs and I'm thinking of picking one up.
On another note, the MC reservoir spacing looks the same on all 3 MCs I've measured (we'll see about the 05+ SD). I'm wondering if the shorter 96/97 MC reservoir might work on the 05+ MC. I don't know what the fitting diameters are yet. Just thinking out loud.
oh OK I thought you said 33s but yeah if 37s or more then by all means step on up to super duty.I'm running 37s now and will be going bigger in the future, I'm sure. That's why I'm moving to 1 ton axles.
I *think* a 1.25" MC might be enough, but I'd rather overkill it than come up short. Good to know you ran that with D60/JD7s. I'll be running the D60 with smaller JD6s. The OBS D60s have 2 x 2.2" pistons/caliper.
Most the SD HB are installed turned 90* with a spacer/adapter to the Dodge MC. The HB bolts are at 12 & 6 oclock, and the spacer/adapter bolt holes are at 3 & 9 for the MC. Something like this would let me install the Astro MC on my Mustang HB, or really any MC. I'd just have to adjust the push rod length. You can see the spacer in this pic. But I'd like have a matched system, and if I'm going to rework for a whole new HB then I'd rather install the larger SD option.
