DanWheeler
Hi all, been a while since I've posted a project thread but got some time on my hands these days
Project:
Upgrade to One-Ton 1.5" Bore Master Cylinder
Why:
Current setup is a 1.25" 1995 Astro master cylinder with matching hydroboost. Because of 1-ton brakes with high volume caliper pistons, fluid volume with 1.25" bore master cylinder is too low for adequate braking. (soft/squishy pedal) Using lots of stainless braided AN3 brake hose and 41" tires probably doesn't help.
Note: The F350 master cylinder does not fit the Astro hydroboost. A matching 2008 F350 hydroboost must be used
Parts List:
- 2008 Ford Super Duty Hydrooboost unit (link)
- 2008 Ford Super Duty Master Cylinder (link)
- 10x1mm to -3AN adapter (www.summitracing.com part: ear-592032erl)
- 12x1mm to -3AN adapter (www.summitracing.com part: ear-592053erl)
- Motorcraft Part#: SW6349 (9F924) (link) OR a 3/8-24 brake line plug
- Wilwood prop valve (www.summitracing.com part: wil-260-11179)
- Two (2) 1995 Astro master cylinder reservoir assemblies (split them apart and use the two larger reservoirs)
There are a whole bunch more parts used here but those above are the most important ones to make this work. The stock reservoir is too tall even with 3” body lift so Astro reservoir is required and just happens to fit perfectly on the Super Duty MC.
Some pictures of parts received so far to get things started:
Project:
Why:
Parts List:
