Maximum angle of rear diff
supersam
Eastern Washington
I'm dealing with a steep driveline issue after my lift and wondering if there's a maximum angle that you can turn the rear differential to, before you have to start worrying about disturbing the oil bath capabilities.
There may be, but even if so, I doubt that you'd get to it, just to correct for a normal lift. Or is this something radical like over 6"?
How much did you lift it and what angles are you dealing with right now?
Don't know the limits, but my thinking is that if you have to tilt the axle back (pinion up) your ring gear is still going to be bathed in lube and so that won't be an issue. The front pinion bearings would be the first to lose their splash/drip lubrication, but I'm thinking you'd have to tilt it up pretty far to get to that point.
Maybe others will know for sure,
What other mods have you done? Shorter driveshaft perhaps, due to adding a longer transmission and transfer case assembly from a swap? Standard Ford 9" rear diff still?
Good luck.
Nevermind. Just saw your other thread about a 5.5" lift, so I'll go check that out now.
Change your shaft to a Bronco-type shaft first. Double-Cardan (CV) at the transfer case is a more forgiving setup for a short wheelbase vehicle like ours.
Then play with diff angle.
