WSM29
- Mar 29, 2010
- 371
So I consider these questions "finish line" questions, but they are pretty confusing to me. I stayed up late last night reading and I want to make sure I have this correct. Once again Ill recap my setup. 93 Mustang roller block, Edelbrock Heads, Explorer Upper and Lower intakes. Running the RJM Harness with a A9P Computer. Keeping the older V belt system.
The intake is not tapped for the ACT Sensor, but I have read I can install this next to the MAF sensor in the intake tube? Thoughts?
I have the complete explorer upper and lower, but I am going to be using the mustang fuel rails and injectors due to the explorer rails having no return line. I also have the mustang EGR and TB. I have read that the elbow on the explorer will cause issues and to get rid of it. How does this effect my BC broncos throttle cable? Can I just bolt the Mustang TB up to the explorer intake with them being 5mm different in sizing? What about the EGR delete kit? Which one do I need for which setup? ?:? Lots of options and I am tried of being dangerous with my money! Is the Ron Morris themacator eliminator kit what I need?
Does the computer need the water temp gauge/ oil sending unit to function properly or can I just use my manual gauges that I ran on my older motor?
Any other hidden gems I should be aware of with this setup? I am in the process of getting the correct 50 oz damper to run with my V Belts, along with the correct 50z 164 tooth flywheel.
I wouldn't mind chatting with someone on the phone if someones got 10-15 minutes to spare today. Just want to clarify these issues.
