OK oK ill give ya a even better idea.......get 1 quart por CLEAR one quart tie coat primer and one quart hardnose paint
POR it prime it paint it.......
You get your POR, and itll look awsowme oh and you get to pick a color other than black! will be tough as nails(nyles...however you wanna say it!)LOL
Im sticking to my epoxy rattle can ...black
Ive got that lil baby blaster for stuff like that!
OX1 your right but does it matter? keen eye!
I'm friends with Tony, I suspect he did it for another reason (clearance for something else). I personally would want full support to the rear, since the highest impact would be in that direction, if you slam into a rock.
Appreciate the advice, but have heard good things about the strength of the POR15...gonna give it a go. However, NYLES has first dibs at "I told ya so!!" if it fails on me ;D
Ok, new irritation. The shock hoop is powercoated. There were a couple chips in the coating (bought em used) and I have heard that once it chips rust will begin. No problem. Ill just clean em up and paint em with the rest of the frame...right? No.
That crap literally just melts under a flap disc. I expected it to come off so much more easily. Couple hours grinding away at it tonight...and a couple more at least to finish. How have others taken powdercoating off?
Anthony
Then I assume your gonna do a header upgrade later? I used P's and mustang FRRP shortie headers they dump on the frame pass side but I think it does turn back a lil not a straight down like in your pic. Not a big issue if you use a 1/2 decent exhaust shop.
When I talked to the guy that does my powdercoating about fixing small chips in the powder, he said to just scuff it a little and spray some quality epoxy enamel rattle can over it. His opinion is that powder coat is the ultimate primer so long as it was applied correctly in the first place and is not peeling.
Thats what I was thinkin before I came back.....dougnuts same direction? Get to paintin!
First pic is deciving
