Mounting Ignition Box Location
Ol'Blue
Is there any reason why I can mount this box vertically to the fire wall? Probably a stupid question but want to be sure. Thanks
No physical reason, as far as the box is concerned. It's just that Ford determined that where it is now is one of the coolest spots in the engine compartment.
The wheel wells, and even the front of the engine sometimes (in the direct air flow from the fan) are cool spots as long as they're not close to things like the exhaust manifolds.
If you have a favorite spot on the firewall though, I would just use it and see how it works. If you have not chosen your spot yet though, I would drive it extensively as you can, then check temperatures at various spots you like. Just in case one is cooler than the others.
We know how hot the floor pan and firewall feel to our feet when there is no carpet, but that does not necessarily mean it's bad for the box. But when in doubt, "cooler is always better" when it comes to ignition modules. Since they even create their own heat, it's best to keep them as cool as possible.
When I tested mine before I did a Duraspark conversion, even though I knew where Ford put it, I tested a bunch of different spots and found pretty much that they'd nailed it for coolest place in the engine compartment on a hot day.
I ended up mounting mine to the leading edge of the wheel well though, where my old wiper/washer reservoir used to be. It was roughly the same temperature as the top of the wheel house, so i was not worried.
Never had a problem.
Oh, and I don't really remember just how I tested for temps while driving. But it was probably pretty low-tech like a kitchen thermometer taped to different points while I drove to work and back.
Or something like that.
Might not be as scientific (or accurate) as some of those temp-sensing stick on thingies, but I figured it worked "good enough" for me at the time.
Ol'Blue
Ol'Blue
Just moving it a few inches away from fender to firewall and will be farther away from header so going to just give it a shot. Thanks as always Paul!
Crush
Greenbottom, WV
Inhave mine mounted to the firewall just to the fender side of the brake booster. Sonfar so good. I Think air flows there pretty good cause of the gap between the firewall and the inner fender
savage
Bronco Nut
Renton
I mounted mine inside the passage compartment.
Ol'Blue
Ol'Blue
Mounted up on firewall. Turned out good.
Rustytruck
Old Blue,
I mounted mine in the exact same spot 20 years ago. It works fine there.
There is airflow down the fender well gap.
Ol'Blue
Ol'Blue
yah, I took Crush's advice. Just need to polish it up and peal that sticker off and put it right side up! Thanks for the assurance, I think it will do fine there too and looks sweet too.
Justafordguy
I like that spot, good air flow and really cleans up the top of the fender well. I may do that mod soon.
Yep, great spot. I have a donor windshield washer reservoir there, so with my toolbox mounted to the wheel well, my next best spot was where the old stock washer bottle was.
Both my Jacobs box and Duraspark box were there for many years.
