Mounting ignition coil
Trappey74
Cleveland
Have to replace my coil and my current one is mounted horizontally beside the carb. My mechanic says they really need to be mounted vertical so where have y'all mounted yours to achieve this?
Like to see some pics of how and places people have mounted them if possible
B RON CO
Statesville, NC
Hi, there is really nothing wrong with the way Ford did it, horizontally in front of the carb. I had to move mine to the left head for "other reasons" I used the original bracket and tweaked it with a minor bend. Some guys put it on the fender away from engine heat, but you will need a longer wire. Good luck
T
Trappey74
Cleveland
[QUOTESome guys put it on the fender away from engine heat, but you will need a longer wire. Good luck[/QUOTE]
That's kinda what I thought about doing as well. The previous owner had new ignition with msd ignition box and accel coil put on it but I don't know how long ago it was but I'd say within last 4-5 years and I'd think a coil should last longer than that. Maybe getting it away from excess heat would make them last longer.
SHX669
I mount mine vertically on the inner fender . If I remember correctly MSD says you can go to a - hmm - 30" or was that 36" - coil to dizzy wire without adverse effects.
pcf_mark
You want air to circulate around the coil on all sides wherever you mount it. Some of the head mount bracket mount the coil up against the head and I think that allows them to over heat. Some intake mounts put them right on top of the heat crossover passage in the intake which adds heat. Some place with some air flow.
Rustytruck
By all measures the best is mounted vertical and in an area with fan flow and the least vibrations. Every thing that Ford did wrong mounting the coil on the Bronco. But Broncos don't normally cook off the coil.
jckkys
If experience means anything, the original location is perfectly fine. 42 yrs. in as hot a climate as any, with 10 Ford cars and trucks, only one coil failed as a result of the oil leaking out. I see no good reason to move it.
I think part of the issue here is what coil is being used. The Ford coils were actually known as one of the best and most consistently manufactured of them back then. Mounting them flat on the intake wasn't recommended for most, but not so bad for a stock Ford one. Since they were in the air flow and, because they were consistently filled with oil, laying down was not a big deal for most of them. I mean, how many of them are still working almost as new, almost 50 years later? A lot of them in fact. Can't say that about many 50 year old car parts.
Aftermarket coils (even the good and expensive ones) don't always have the full measure of cooling oil inside (or at least they still prefer you mount them vertical to avoid even the occasional trouble), so laying them on their side can definitely be detrimental to their health. Mounting vertically leaves the fewest windings exposed to air if they're a tiny bit low on oil. Laying the same coil on it's side can expose a greater amount of wire inside. Leading to overheating and failure.
Any oil-filled coil can suffer from this (hence the excellent advice to mount vertically) but the OE Ford coils were particularly well made and filled with oil. Which let them get away with mounting sideways more often.
Even the ones on some engines that were mounted directly to the cylinder heads were able to overcome the high heat area because of vertical mounting and good direct air flow from the fan, and as few of the inner windings exposed as was possible.
As jckkys said, it worked pretty good all these years now.
But when using a non-original coil... Get it to a cooler spot and put up with the longer wire. And whenever possible, mount it vertically.
But you usually don't mount them too close to the ignition control modules like that MSD6. Not for the coils' sake, but to keep interference "noise" away from the electronics.
That's the nice thing about the modern E-core coils, and even the old canister looking style that are filled with epoxy instead of oil. Good vibration and heat resistance, and can be mounted just about anywhere and in any position. But if you notice, all the modern engines that still had distributors and one coil usually tended to mount the coil away from the engine.
The exception being the GM HEI which still had it on the engine basically, until whenever they stopped using that design.
If you must replace your coil then, but want to keep the OE look and lay it on the intake, I would opt for an epoxy filled version.
blubuckaroo
Grease Monkey
Ridgefield WA
The reason Ford attached the coil to the engine is for the assembly line economics. The engine was put in as a complete package.
"Ready to run."
T
Trappey74
Cleveland
Picked up a MSD blaster 2 from auto parts store and mounted it back in the stock location just long enough to get it home and I may look at remounting it somewhere later. I did soak up some oil from the acres coil that was on there
