- Joined
- Apr 26, 2015
- Messages
- 2,628
Do you have a body lift?
This style injection is on my list, but I want a traditional air filter or a stock style. I have a 1" body lift.No, original, 40 year compressed, body mounts.
I am wrestling with the idea of a stock air cleaner or not.If you have a 1” BL and you use a filter that is in the 2”range, you should be good with a traditional air filter on a 302 or 351.
Nice! I had a '71 Comet with 302 auto.......Fun little car.It was a 69 Maverick with a 160 6 cylinder and 3 on the tree.
Thanks for the great write up! It has convinced me to go Q-jet. Call me old school. Or lazy. Or cheap. And I wasn't driving a Bronco during the Nixon administration. It was a 69 Maverick with a 160 6 cylinder and 3 on the tree.
- I abandoned the original evap cannister behind the drivers seat and added the Delorean rollover valve (mounted on the outside of the frame rail on the passengers side) and Doorman vapor cannister (mounted to the firewall on the passengers side). 5/16" hose comes from the M1A1 tank to the rollover valve and from the rollover valve to the vapor cannister. 3/8" hose goes from the cannister to full time vacuum at the back of the intake. In my mind, this should seal up gas fumes/vapors, but it still seems pretty strong in my garage. If you've made it this far in the post and have any ideas, I'm all ears.
Sorry, I am still a little confused. I understand tanks need to vent. But the M1A1 pump assembly comes with a S (Supply), R (Return), and V (Vent). The installation manual says you can cap off the vent line if you are in a state that does not require emissions (or something close to that, I am not looking at it right now). So I capped it off. There is also a vent hose near the filler. I intend on using the vent near the filler hose if this is correct. The OP talked about using the vent line on the pump assembly and an evap canister and I am asking why? Sound like it is for the smell but wondering if that was effective or not. Making sure I am not missing anything. Thanks!Two primary reasons. I’m sure there are more, but the two most basic are:
1. Gas expands and contracts as it heats and cools just from the natural progression of temperatures.
This is why older non vented tanks often puked fuel out of the filler neck and onto the nice paint.
2. You need a pressure relief, to let air inward, as you’re sucking gas out of the tank and going to the engine.
Without that, either your tank implodes, or your engine stops running because the pump can’t suck the fuel.
I’m not aware of any standard pumps that are strong enough to crumple a good strong tank, but it’s theoretically possible.
You can accomplish some of that venting with a standard non-vented cap because they are still vented inward to allow air in to take up the space previously taken up by gas. But it’s not always enough when your engine is demanding a lot of fuel.
And that still doesn’t leave anywhere for the expanding gas to go, so it still pukes out the filler neck.
That’s part of the job of that separate tank in the Broncos behind the drivers left hip, to act as an expansion tank.
To allow for some of this expansion (in small tanks with less than optimal expansion space on top) without liquid gas getting into the charcoal canister.
That’s my theory, and I’m sticking to it.
For now… Until someone smarter fills in the blanks.
Basically what @DirtDonk @duffymahoney and @73azbronco said. Yes, it has been effective in my scenario as far as fumes/smell.Sorry, I am still a little confused. I understand tanks need to vent. But the M1A1 pump assembly comes with a S (Supply), R (Return), and V (Vent). The installation manual says you can cap off the vent line if you are in a state that does not require emissions (or something close to that, I am not looking at it right now). So I capped it off. There is also a vent hose near the filler. I intend on using the vent near the filler hose if this is correct. The OP talked about using the vent line on the pump assembly and an evap canister and I am asking why? Sound like it is for the smell but wondering if that was effective or not. Making sure I am not missing anything. Thanks!
Glad the parts list helped.Love this post/thread. Printed out the parts list for reference (Thanks!) - wish I had kept my own. Here's my experience:
I had a complete Explorer '96 setup with distributorless ignition and everything installed. In fact I was at the point of having EFI Guy do my harness (it was my turn "in line"), when I learned that Gary would be unable to work around EGR, Evap and a few other things due to stupid regulations (not that he couldn't, the government won't let him).
I had previously steered clear of "aftermarket" EFI before for two reasons: The ECU was in the throttle-body, and they were essentially 80's era throttle-body electronic carbs! About the same time Gary called me to do my harness/computer, I became aware of Pro FLo 4 which had none of my earlier holdbacks. I reluctantly gave up my turn in line and thanked Gary, then ordered a Pro FLo 4.
It took about 2 days to remove the Explorer stuff and get the Pro Flo 4 installed. It took about another week to finish the fuel system as I ordered a fuel pressure regulator from WH. I would say 30-40 HRS total to remove old and install Pro Flo 4 - but I still had a Painless wiring harness to install and life got in the way!
Nine months later, I complete the Painless install, pour fuel in the tank and it starts on the first try! Not only that, it was running great! Maybe a little rich. I let it come to temperature and shut it off in the shop a few times and then took it for a drive. It ran great on the drive. No hesitation, missing or other bad behavior. And I think it is learning we are in Flagstaff and leaning out the mixture a little because it is no longer smelling rich.
Now I am applying finishing touches (like a soft-top and doors) and getting ready to use it as a daily driver before my first 4by event in January!
I couldn't be more pleased with the Pro FLow 4! About the only sacrifice I made was to have to retain a distributor instead of full electronic ignition.
THX,
-John
I was driving a Bronco...Thanks for the great write up! It has convinced me to go Q-jet. Call me old school. Or lazy. Or cheap. And I wasn't driving a Bronco during the Nixon administration. It was a 69 Maverick with a 160 6 cylinder and 3 on the tree.
Do you have VSS and NSS connected? I have no idea what ignition you have.Glad the parts list helped.
4-5 months in, my experience has been mostly good. Cold and hot starts are great. No hiccups or issues while driving. The only issue I've had with just the PF4 system is dying when putting into gear after hot starts. It seems to do this pretty consistently. I can usually feather the gas pedal to prevent it from doing it, but it happens while putting it into gear, so I have to have room wherever I'm parked to be able to move faster than I want to out of that place. It's annoying and something I shouldn't have to do.
I posted the issue on the PF4 forum and one of the moderators suggested starting the engine while in neutral and seeing what happens. For whatever reason, that solves the problem. But, again, I shouldn't have to do that. I don't know enough yet to know why this makes a difference.
I also thought it could have something to do with engine bay temps. Since it always occurs after hot starts, that's usually a scenario where I've been driving, parked, done whatever it is I need to do, and by the time I've come back, the engine bay temps have continued to rise. The coldest air temp reading I've had where this happens is in the 130's and the hottest temp has been in the 150's. From what I've read, these aren't crazy high engine bay air temps in general, so not sure if the air temp the system is reading is an issue or not.
I'd be happy to heat any thoughts anyone might have.
