Bundy
- Jan 10, 2009
- 2,045
After browsing around for ages on here I finally pulled the trigger and jumped into getting rid of my rusted out rockers and replacing them with 2x6 3/16" rectangular tube to provide ultimate protection out on the trail.
I started by measuring down from the sill about 3/4", taped a line and started cutting with an angle grinder with a cut off disc for the outer line and had to use the ole sawzall for some of the inner where it connected to the door post.
As you can see, both the inner and outer rocker were pretty much destroyed so I opted to weld supports to the frame instead of welding them to the inner rocker.
