Narrow 35" tire?
halfgassed
marquette Michigan
Q78's. A buddy runs them on factory chevy 2500hd wheels ( I think are only 7.5" wide????????) looks very well proportioned.if you did want to go 16" wheels try 9.00 x16s. I just mounted a set of old mccreary superlug 9.00x16s on my firewood hauler, measure a true 35.5" tall, they are as tall as the 38.5x14.50x16.5s they are replacing, and fit on a stock steel wheel.
duffymahoney
I'm looking for tires to fit a 7" wide 15" wheel that are 35-36" tall. Don't want an aggressive mud type either, which seems to be most of what's out there in the "tall and narrow" department. Anyone got a lead on what I'm missing?
If I have to, I can get the wheels (Coker Tire steelies) in 8" width too..but I'm trying to stay as skinny as possible with these.
Why?:) I think they will look goofy
AZ73
68ford
They're on beadlocks that's why there isn't a problem.
The more narrow the wheel the more positive outward pressure on the bead. Less likely to need a bead lock. You are much more likely to blow a bead on a 10in wheel than an 8 never less a 7 or 6.
Casey835
I’ve been looking at those power kings for quite some time, just need to find the wheels. I think they would look badass. Tall and skinny.
surfer-b
The old Gateway Buckshots are being made again but in only N78x15 (31x9.5) and P78x16 (33x10) those are approx. sizes in inches. https://ok4wd.com/gateway-buckshot-mudder
Here is a set of old P78x15 on my 76 with stock Bronco wheels, when they were new they actually measured ~33.25" on stock 5.5" wide wheels @28psi
Tall skinny tires are not easy to find anymore and not much to select from, the 255/85/16 will get you the best selection nowdays
darkmagus
Narrow 35" tire?
I agree on the 255/85s. I had them on my old Tacoma and loved them.
