I put them on all the race stuff. Summit has them but I believe under a different brand, I usually ge them from trail gear or spider trax. Makes inspections cake or in a race environment dumping in oil at a hi rate of speed from a gallon jug
Glad you are keeping constructive on your sat afternoon![]()
Personally I would fit them to fit closer, better weld less heat. I've never had a housing warp when the parts fit good and you not filling with welding wire forcing in more heat.
If possible on stock housings I just weld everything and recheck for straightness after completion and straighten as needed. On heavy aftermarket housings it's really not necessary.
These are made to fit 3-1/4 tube and 3-1/2 tube. Just grind the notches off to go to the bigger. Lots of cutting to make them fit without the gap. I think I'll be good using heavy tacks and taking my time.
Using these means putting them on the springs loosely, jacking the housing up under them, making sure they are seated right, then welding. I don't really want to be in and out 19 times with it, if you know what I'm saying.
