broncochevy
Okay, I have a 1972 F100 rear end with large center section, 31 spline axles, 11 x 2 1/4” breaks, and large bearings. Is it possible to narrow it to the width of a 1977 bronco rear and use the “stock” bronco length axles (if a replacement would be needed) and even cut and respline these truck axles to bronco size? The reason I want to do this is threefold, it may be cheaper than a totally new housing, and it would be an upgrade from the small bearing 9 that I have already for my bronco, and I have this rear already. It has the ratio I want and it looks to me like a wider version of a 77 bronco rear with the same size brakes. I searched and found threads with “holes” in them as in they weren’t totally finished or not much explanation. I do know that at one time narrowing 9 inch rears was commonplace especially in the hot rod scene. Searched in those types of forums and found that those guys use early bronco rears in their rods as they don’t need narrowing because they are the perfect size. Just wondering...as my budget isn’t exactly like that of a coyote bronco build. Naw mean??
