KBUCK1
- Feb 8, 2011
- 979
I have installed all new braking system. Original 76 disc brake setup in front with drums in the rear. It's a manual brake system with ram charger master cylinder. Also, i have h block installed instead of proportioning valve.Brakes have been bled what seems like a hundred times. No air is coming out. Master cylinder was bench bled 6 or 7 times at this point. Plugged master cylinder ports and pedal does not move. So, Im good there. Here's the problem.the pedal goes down about half way and is very spongy. Rear drums are adjusted where they are dragging on drum. I jacked the truck up and had my wife mash the pedal as far as she could and I could still turn he tires in the front and the back. When bleeding the brakes the pedal will go to the floor but with the bleeders closed it only goes half way but still no brakes. Calipers are installed with bleeders in the highest position. Any suggestions on what the problem might be?
